fuel setup problems
Old May 5, 2008 | 10:11 AM
Will_H's Avatar
Default fuel setup problems
Just installed a dual walbro setup on my boosted teg with -8 feed line and -6 return. Started right up and i got the fuel pressure around 45psi, Drove it and it seemed fine A/F ratios where fine , so i ramped on it some and then crusied for alittle while then shut the car off. I got back in and it started up but as soon as i went to let the clutch of it died. It seems as if as soon as you put a load on it or even give it gas it stumbles and wont rev over 2k. I've checked the power coming out of the pumps and it's fine, also fuel is flowing through the lines no problem. Any ideas on what to do next im kinda lost as in what to look for. I've also tried ajusting the FPR and the gauge reads 0psi at idle. Thanks
Old May 5, 2008 | 03:22 PM
Will_H's Avatar
Default Re: fuel setup problems (MMMMMbaaaaaaaaaah)
anyone?
Old May 6, 2008 | 05:13 AM
Devo94ac's Avatar
check your plugs
Old May 6, 2008 | 05:19 AM
daveedd357's Avatar
Default Re: fuel setup problems (Devo94ac)
make sure you have gas in the car
Old May 6, 2008 | 06:18 AM
red02s2k's Avatar
Default Re: fuel setup problems (daveedd357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveedd357 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have gas in the car</TD></TR></TABLE>
I would hope you would now if you had gas
Zero psi at idle i don't understand if you had know pressure the car shouldn't be running.
Old May 7, 2008 | 08:53 AM
Will_H's Avatar
plugs are fine and it has a full tank of gas. It seems as it if it only has enough pressure to idle, soon as you hit the gas is bogs. Also no fuel is coming out of the return line. no kinks in the lines either
Ty05
Sep 22, 2009 08:38 AM
batallic
Nov 2, 2008 02:39 PM
95greenteg
Oct 11, 2005 08:48 AM
letholone
Aug 15, 2003 12:58 PM
acuraintegraman
Aug 27, 2001 05:23 AM
