fuel setup for d16 & nitrous
Old Dec 25, 2003 | 08:19 PM
blackeg's Avatar
Default fuel setup for d16 & nitrous
this is what my setup will be- d16z6, skunk2 valvesprings& st 1 cam, str camgear(probably retarted -2) hdss clutch, zex colder plugs, msd wires, new cap and rotor and an nx wet kit probably set up for 50 shot. what fuel upgrades should i do??? i have an aem fpr that will get put on soon. was thinking about fuel pump. can i get away with the 190 or should i get 255lph one?? other suggestions are welcome too
Old Dec 25, 2003 | 08:40 PM
gsracer170's Avatar
Default Re: fuel setup for d16 & nitrous (blackeg)
first of all, get rid of the zex plugs. go out and get some ngk ones.
for a 50 shot, you should be good w/ the stock pump. just to be on the safe side, go out and get a 255 fuel pump. you shoudn't have to retard you timing 2degrees for a 50 shot, stock timing is ok.
Old Dec 25, 2003 | 11:39 PM
sting94112's Avatar
Default Re: fuel setup for d16 & nitrous (maingear)
bump, i want to know too, if you have to upgrade the fuel pump, injectors, fuel rail, or get a fpr. I will be running 55 shot Zex on my stock b16 del sol.
Old Dec 26, 2003 | 01:47 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: fuel setup for d16 & nitrous (sting94112)
stock parts will be fine on 55-65 ZEX shot.
75 shot things get borderline.
Old Dec 26, 2003 | 08:37 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maingear &raquo;</TD></TR><TR><TD CLASS="quote">first of all, get rid of the zex plugs. go out and get some ngk ones.
for a 50 shot, you should be good w/ the stock pump. just to be on the safe side, go out and get a 255 fuel pump. you shoudn't have to retard you timing 2degrees for a 50 shot, stock timing is ok. </TD></TR></TABLE>
the cam timing will be retarted to get the most gains out of the cam- regardless of the nitrous
TylerC
Jun 20, 2005 10:14 AM
DarkBB4
Nov 4, 2004 12:18 PM
1INTEGRA
Feb 23, 2004 01:21 PM
tmekjian
May 1, 2003 09:53 AM
CM-R
May 7, 2002 01:43 PM
