????? Fuel Pump ??????
Old Jun 18, 2003 | 05:48 AM
Screamer's Avatar
Default ????? Fuel Pump ??????
What fuel pump would you guys recommend. My goal is about 400whp. I will be running 85lb injectors and I need to find out what to do with my fuel pump. Is there any intank fuel pumps that will handle the job. Currently I have a Walbro 255g/h fuel pump.
Thanks for the help.
Old Jun 18, 2003 | 06:40 AM
Flamenco-T's Avatar
Default Re: ????? Fuel Pump ?????? (Screamer)
you should be fine with the walbro. with 85LB injectors, you're not having to push out that much at normal duty cycle
stan
Old Jun 18, 2003 | 07:28 AM
Screamer's Avatar
Default Re: ????? Fuel Pump ?????? (Flamenco-T)
How reliable is the Walbro pump???? I don't want anything to happen when I am on a road course.
Old Jun 18, 2003 | 07:29 AM
Flamenco-T's Avatar
walbro is reliable, a lot of ppl run them for years, just as logn as you're not pushing too much pressure out of it ~ too much voltage, you'll be fine
stan
Old Jun 18, 2003 | 08:06 AM
Screamer's Avatar
Thanks for your feedback.
The reason that I am asking all of these questions is that recently I have started to hear some noises coming from the pump that I have not heard before. Before all I heard was an isolating sound of the pump now I hear some screaches etc... any idea of what that could be.
Thanks.
Old Jun 18, 2003 | 08:24 AM
Flamenco-T's Avatar
usually with fluctuating voltages, the fuel pump will make a different noise.
stan
Old Jun 18, 2003 | 09:17 AM
Screamer's Avatar
Good thing to know... I will check the voltage.... I also think that I may be in need of a new battery..... Odyssey comes to mind
EJ8CIVIC
Jul 5, 2015 12:07 PM
mr devious illusions
Mar 24, 2007 11:19 AM
VspecSiR
May 17, 2004 04:37 AM
