Fuel Problem with turbo
i just got done putting a gsr motor into my hatch. with my old single cam motor the fuel pressure was reading 50 psi and i have been trying to lower the fuel pressure to 40 psi on the stock fuel regulator. now with the gsr stock fuel pressure regulator its reading 60 psi. DAM IT.
-i have checked for leaks in vaccum lines and have followed the haynes way of releasing fuel pressure. NOW I CAN'T FIND ANYWAYS TO LOWER FUEL PRESSURE.
-when i take off the vaccum line for the fpr. the pressure goes up to 65 psi. can it be my fuel return line and if it is how do i fix the problem. also i changed the fuel filter with a new one and i have a walbro 255 intank fuel pump.
PLEASE HELP!!!!!!!!. HAVEN'T SOLVED THIS PROBLEM FOR 4 MONTHS NOW WITH THE SINGLE CAM AND WILL NEVER IF DON'T FIGURE THIS OUT. FLOODING MOTOR WITH DSM 450'S EVEN AT 50 PSI ON FPR. NO BOOST TOO MUCH FUEL
you need to drill out the fuel pressure regulator. check out http://theoldone.com/articles/regulator/
please help me solve this problem. i have a b&M fpr but the lowest it will go is 50 psi. how do i lower my fuel pressure and what are the causes of the fuel pressure going up. i also have a walbro 255 intank fuel pump. can that be the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha_1 »</TD></TR><TR><TD CLASS="quote">please help me solve this problem. i have a b&M fpr but the lowest it will go is 50 psi. how do i lower my fuel pressure and what are the causes of the fuel pressure going up. i also have a walbro 255 intank fuel pump. can that be the problem?</TD></TR></TABLE>
The B&M unit is only adjustable in the sense that you can increase the pressure...using the B&M you cannot lower the fuel pressure below stock static fuel pressure. With your walbro pump pushing a higher volume, you are going to experience the increase in fuel pressure. I too was getting about 50 psi after installing my walbro and was unable to adjust it down.
You have two solutions. The first one has already been mentioned:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv »</TD></TR><TR><TD CLASS="quote">you need to drill out the fuel pressure regulator. check out http://theoldone.com/articles/regulator/ </TD></TR></TABLE>
Your second solution is to ditch the B&M for a regulator that can be adjusted down...like an Aeromotive, Paxton, AEM, or SX.
superhatchbackbros
Oct 7, 2006 10:51 PM
teknics1
May 29, 2006 12:30 PM
