Fuel Pressure Regulator leak?
Old Dec 19, 2002 | 09:10 PM
swrdply400mrelay's Avatar
Default Fuel Pressure Regulator leak?
Ok I got an adjustable fuel pressure regulator with a gauge on it. The style is similar to the SX one. My problem/question is: The two fuel nipples on it seem to be leaking a very little amount of fuel. When I turn on the car and rev it a few times, no drips of fuel or anything, not even if I drive it around town. BUT, there seems to be a sludge of fuel around them anyway. Is this normal? Should I get some AN wrenches and tightend down those nipples? Or will this damage the FPR?
TIA
[Modified by swrdply400mrelay, 6:11 AM 12/20/2002]
Old Dec 20, 2002 | 05:46 AM
tony1's Avatar
Default Re: Fuel Pressure Regulator leak? (swrdply400mrelay)
You have orings on the fittings going into the regulator, right? That is how those seal.
Old Dec 20, 2002 | 07:06 AM
Default Re: Fuel Pressure Regulator leak? (tony1)
Well, this isn't exactly like the SX. It doesn't have AN fitting with stainless steel lines like the SX (if I remember correctly). The fuel nipples are threaded and wrapped with teflon tape. You can see the teflon has turned orange on the blue nipple (also on the red). Sorry for the bad images; I got a cheap digital cam.
<IMG SRC="http://www.geocities.com/swrdply400mrelay/fpr1.jpg
" BORDER="0">
[Modified by swrdply400mrelay, 6:56 PM 12/20/2002]
Old Dec 20, 2002 | 09:59 AM
If you get a big red x, go here for the pic:
<A HREF="http://www.geocities.com/swrdply400mrelay/
" TARGET="_blank">http://www.geocities.com/swrdply400mrelay/
</a>
Old Dec 21, 2002 | 09:53 AM
ttt
Old Dec 21, 2002 | 10:28 AM
JM Performance's Avatar
im pretty sure fuel eats true teflon tape....
Old Dec 22, 2002 | 05:29 PM
Default Re: Fuel Pressure Regulator leak? (00SilverLS)
Then what do you use to seal?
Old Dec 22, 2002 | 05:39 PM
tony1's Avatar
Teflon tape should seal fine on fuel. Are the threads on the fitting tapered? Look at them real closely and see if the taper at all from where they start to where they end. If they are tapered, they are pipe thread and need teflon tape to seal. Those fittings get tighter and seal as you tighten them. If it's leaking, put some new tape and tighten them some more.
zCivic
Sep 7, 2006 02:42 PM
xbn83
Dec 3, 2004 07:12 AM
JM Performance
Dec 20, 2001 03:51 PM
chefcris420
Jul 20, 2001 11:34 AM
