Fuel Pressure.....
Old Apr 4, 2002 | 11:34 AM
DR. ON POINT's Avatar
Banned
Default Fuel Pressure.....
Can someone explain this whole theory to me. I am totaly oblivious to this whole subject, but it seems importnt so I should learn....help a brotha out
Old Apr 4, 2002 | 11:35 AM
dustin's Avatar
Default Re: Fuel Pressure..... (On Point EK)
be more specific... ?
Old Apr 4, 2002 | 11:39 AM
Banned
Default Re: Fuel Pressure..... (dustin)
mm.....ok how about this....I have no clue what fuel pressure is. I got no clue on how to read it, what it does, what u have to do to make it increase, make it decrease, the advantages of having high fuel pressure, the disadvantages.etc.....
Old Apr 4, 2002 | 11:40 AM
dustin's Avatar
Ok well, hmm...
read this it might help a little
http://toyotaperformance.com/fuel_pres_reg.htm
Old Apr 4, 2002 | 11:46 AM
Banned
ok well that helped out.....u get a fuel pressure regulater to control the amount of unused fuel going back to the gas tank, stock is between 38-44 psi., what are the advanages and dsadvanteas, when running larger injectrs in a turbo car say, 440's, u would wan to increase the psi.?
Old Apr 4, 2002 | 01:38 PM
Rain_man's Avatar
New User
Regardless of injector size, you increase pressure to increase the amount of fuel being dumped into the cylinder. The reason why you use larger injectors is so that you can flow more fuel at lower pressures. Lower pressures are good because you run into complications with higher pressures
Old Apr 4, 2002 | 02:07 PM
TurboSedan's Avatar
New User
Default Re: Fuel Pressure..... (DarksideDC4)
......such as the fuel pump not being able to flow enough at those higher pressures to support the power your engine is trying to put out. That is a bad thing, you go lean and will blow the motor. Lower fuel pressure is a good thing when you can still support the power you need to make.
danno33
Dec 27, 2006 02:16 PM
Turbocivic94
Dec 24, 2005 09:12 AM
tolowhb
Apr 6, 2004 06:42 PM
djnikko
Dec 7, 2003 10:42 AM
iwouldHITit
Mar 8, 2003 09:52 PM
