fuel line for to fuel rail. Problem
Old Oct 21, 2003 | 12:42 AM
rjardy's Avatar
Default fuel line for to fuel rail. Problem
Where can I get the fitting that i need? Factory it uses a banjo style fitting. I would like to retain the facotry hose and banjo fitting but need to know where I can get the correct fitting that goes into the fuel rail. How do guys normally do this? It is an STR competition fuel rail. I know that I need a plug for the other end, but im concerend with the feed side. How are guys normally running it on there fuelrails.
Rob
Old Oct 21, 2003 | 12:53 AM
Kwuaymaikrup's Avatar
Default Re: fuel line for to fuel rail. Problem (rjardy)
I just took the stock feed fitting off of the stock rail.
-Ryan
Old Oct 21, 2003 | 12:55 AM
rjardy's Avatar
Default Re: fuel line for to fuel rail. Problem (Kwuaymaikrup)
How did you do that? is it not pressed in there? this is an LS fuel rail that I have. allso are you running an STR rail?
Old Oct 21, 2003 | 03:43 AM
rjardy's Avatar
help me out!!
Old Oct 21, 2003 | 07:19 AM
White Smoke's Avatar
i my honda
Global Mod
My Str rail came with the right peice for the end. I may be willing to sell since I will be runing all bradid lines. I will let you know.. Pm me an offer man
Old Oct 21, 2003 | 07:30 AM
espanol's Avatar
fast-turbo.com
Old Oct 21, 2003 | 07:34 AM
R6Elmo's Avatar
Default Re: fuel line for to fuel rail. Problem (espanol)
What you have to do is get the stud remover and remove that bolt. I tried to find 2 nuts in that thread.but i believe it's a really odd thread. The banjo bolt from fast-turbo is kind of odd as it's not the same shape as the stock banjo bolt and doesn't fit properly in my LS rail.
Danny
Old Oct 21, 2003 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">How did you do that? is it not pressed in there? this is an LS fuel rail that I have. allso are you running an STR rail?</TD></TR></TABLE>
It was off of an LS rail as well. Came from my G2 Teg. I am using the AEM rail but I would assume that the threads are the same.
-Ryan
Old Oct 21, 2003 | 12:36 PM
rjardy's Avatar
Thanks guys, I will try and remove it today.
Rob
Old Oct 21, 2003 | 10:32 PM
rjardy's Avatar
well i tried it and it wouldnt come off.
And evan if it would it doesnt look like it would fit anyhow. any more ideas?
Rob
HpRevolution
May 23, 2007 09:42 AM
Mr. Anderson
Feb 21, 2005 08:01 AM
Matt B
Jun 9, 2004 09:00 AM
976
Jul 15, 2003 07:00 AM
B18EG6
Jan 8, 2003 12:24 AM
