Fuel Issue and question with walbro fuel pump
Old Apr 10, 2009 | 02:05 PM
Maple50175's Avatar
Default Fuel Issue and question with walbro fuel pump
Hey I have a question can you run a walbro 225l fuel pump if your car is stock? mine is but I'll be boosting and I have some issue where when I start car and give it gas its fine for a second but then when i start moving the car wont go and i could gas it to the floor and well nothing happens like its not getting any fuel or something then all of a sudden it works and everything is fine and dandy. This is only apon startup.
Things I was told to look at:
Fuel Pump, the two FI Relays below glove box, Fuel filter (in gas tank) or regualtor also in gas tank.
Someone also mentioned bad ECU?
How can I figure this out? ugh
If i have a walbro fuel pump I dont need a return line correct?
Old Apr 11, 2009 | 07:07 AM
Maple50175's Avatar
Default Re: Fuel Issue and question with walbro fuel pump
noone knows eh
Old Apr 11, 2009 | 07:26 AM
BDaTurboTeg's Avatar
i dont see why u wont be able to run the walbro with a stock motor.....have u checked ur injectors also? fuel rail? ......ive noticed wit fuel stuff it could be one of those many things....i thought my walbro had crapped out because i hit a bump and my car shut off......then i got it home and the pump wouldnt even prime...found out it was the fuse kept blowin....i changed it a few times and everytime i started the car it would blow....i took the pump out of the tank and check the wires thinkin it was shorting out....didnt see anything so i put it back in and changed the fuse ...next thing the car starts....and has been runnin wit no problems since....i have no idea wtf happened lol but idc cause it runs and the fuse doesnt blow
jastonian106
Feb 28, 2015 09:03 PM
hondaapi
May 13, 2010 11:39 PM
IAteg
Nov 11, 2005 12:34 PM
NumberB
Dec 13, 2003 10:52 PM
Hispeed
Jul 13, 2001 09:16 AM
