fuel and head bolt question
Old Jul 27, 2013 | 01:39 PM
Evansouders's Avatar
Default fuel and head bolt question
On my vitara/eagle zc d16 with z6 head how much hp will the stock injectors and fuel pump put out or should I just get the dsm 450cc injectors walbro right away? Asking cause I'm on a budget thanks.
Old Jul 27, 2013 | 02:25 PM
grumblemarc's Avatar
The Grumpiest
Default Re: fuel and head bolt question
1,000,000 horsepowers!!!
Old Jul 28, 2013 | 01:04 AM
frost_white_ej1's Avatar
research! research!! research!!! Google! Google!! Google!!! oh! did i mention research!
Posted from Honda-tech.com App for Android
Old Jul 28, 2013 | 05:51 AM
Muckman's Avatar
Moderator in Chief
"head bolt" is in the subject but there is no mention of head bolt in the post? lol
Old Jul 28, 2013 | 06:07 AM
RACEPAK's Avatar
yup 1.000.000 hp
Old Jul 28, 2013 | 06:25 AM
Turbo-LS's Avatar
So wait you had money to build a piston and rod motor but didnt take into account that more air ( forced induction) wouldnt need more fuel when creating more power? EPIC FAIL. Should have left the motor stock and done the things you NEEDED to do and boosted that. NO stock injectors wont work for any boost. Stock pump maybe a couple of pounds but for 90 bucks is it even worth the risk ?
Old Jul 28, 2013 | 06:52 AM
The Grumpiest
If you cannot afford to upgrade the fuel system then you definitely won't be able to run any modern tuning solutions. Better start looking into the crude FMU method and cross your fingers. And since you mentioned head bolts I'm going to assume that you haven't upgraded those either?
DOHCED8
Mar 29, 2009 09:44 AM
MyHotsh
May 8, 2006 12:02 PM
2.2EL
Dec 4, 2003 07:59 AM
