Fuel Gurus chime in! E/C/Q
Old Aug 10, 2013 | 07:32 AM
Snailor Built's Avatar
Default Fuel Gurus chime in! E/C/Q
Why do a majority of people go with e85 over the q or c16? I can understand one variable would be the price. However I cant help but to think of how much more power can be made running one of the 2 over the E because of the consumption of fuel required by the e? Explaint please!
Old Aug 10, 2013 | 07:59 AM
twkdCD595's Avatar
Default Re: Fuel Gurus chime in! E/C/Q
Changing from leaded race gas to ethanol based fuel (e98 in my case) was a combination of cost, less toxic than dealing with leaded fuel, supports huge power, and the added bonus of chemical cooling effect.
If on a conventional race fuel, you can also pickup a little power retuning on ethanol.
The only downside for me was the need for a larger fuel system (I was about at the limit of my previous fuel setup anyways). Pair of 044 pumps, -8AN feed to rail, and going from ID1000's to ID2000's fixed that (already had a Weldon regulator, larger rail, etc.).
Old Aug 10, 2013 | 08:17 AM
mar778c's Avatar
Community Builder
Community Influencer
With the right set up, FTW e85 can help produce well over a 1000 whp. It is expensive as is any race gas.
Old Aug 11, 2013 | 12:54 PM
Turbo-LS's Avatar
C16 allows for more ignition timing and boost pressure over pump gas which is why you make more power. Q16 will pick up power over C16 because its oxygenated and Ethanol will pick up power over both and run cooler because its alchohol, it requires more fuel system but in the long run is a lot cheaper to run. Depending on injectors that are being ran you either have to run the car on a schedual to kep the injectors from seizing because alchohol dryes them out and pulls in moisture which causes rust in certain injectors. OR you can pickle the system by draining the alchohol and running the car on pump gas for a few minutes to treat the system
Old Aug 12, 2013 | 09:14 AM
You are the man as usual, thanks for clearing that up.
Old Aug 12, 2013 | 09:47 AM
wantboost's Avatar
Who is Mr Robot?
Nothing smells like q16 though. I keep the 5 gallon pails and use them as air freshener in my room lol
Old Aug 12, 2013 | 12:15 PM
Turbo-LS's Avatar
What fuel do most Rotary's run is that VP import ? Whatever it is smells amazing! its like cotton candy in the air haha
Old Aug 12, 2013 | 12:54 PM
haha yall are crazy, I had some "turbo blue" in my r1, I blew it up at the track and got the bike home and had it torn apart before my girlfriends birthday party. Well long story short half tank of it, sitting on the work bench, drunk people in a attached three car garage, with all hvac going through the garage, and somone spilled the tank, 4:30 in the morning woke up with a headache that lasted a week, thought I had a tumor or something haha.
Old Aug 12, 2013 | 04:18 PM
Muckman's Avatar
Moderator in Chief
The biggest reason I run E85 is because its available at my local gas station. Its not a race fuel that I have to special order.
Old Aug 12, 2013 | 06:03 PM
Turbo-LS's Avatar
I think I'm going to make my own e85. 55 gal drum of e98 blended with some pump 93 and top end lube
Old Aug 13, 2013 | 12:30 AM
wantboost's Avatar
Who is Mr Robot?
That might not be a bad idea
Meth injection is just easier for me. I can pickup a 55 gallon drum for 140 and make my own blends from there, maybe even experiment with mixing methanol with pump 93 as a primary fuel... m50 or something lol
Old Aug 13, 2013 | 12:33 AM
wantboost's Avatar
Who is Mr Robot?
And speaking of off. I have a can of U4 we run in our liter superbikes laying around and it has a tiny bit left in it. Like enough to put in an empty spray/cologne bottle... VP racing fuels for men
Old Aug 13, 2013 | 03:57 AM
tepid1's Avatar
You'll need a chemical binder for that. Same with ethanol. You may think it cuts it, but in reality it never mixes well.
I've had a coworker (Chemist) fully break down the FTW purple fuel. I know exactly what is in it and what had to be done to get the different chemicals to work together.
Old Aug 13, 2013 | 04:52 AM
Turbo-LS's Avatar
What kind of chemical binder would be nessesary for ethanol
Old Aug 13, 2013 | 04:54 AM
tepid1's Avatar
Believe it or not, it's stuff that you can get at your general hardware store.
Try it yourself. Put e85/98 in a graduated cylinder then add pump gas to it. What happens?
Old Aug 13, 2013 | 01:47 PM
wantboost's Avatar
Who is Mr Robot?
It separates. Specific gravity is a bitch lol
So about FTW, any truth to the drama around the fuel?
I thought about putting some through gcms
Old Aug 14, 2013 | 12:37 PM
crxtc_vtec's Avatar
I would like to know more about fuel choices as well!!! Cool topic! Im up in the air about staying on E85 or going Q/c 16
Old Aug 14, 2013 | 05:08 PM
Turbo-LS's Avatar
Tepid leaned me in the direction of e85 from ignite. I like the price and its consistent blending. C85 from vp would make more power but its 10 a gallon
Old Aug 15, 2013 | 05:46 AM
twkdCD595's Avatar
Glacial Plains is another good source for race E98.
Old Aug 15, 2013 | 05:55 AM
2000CTRSi's Avatar
Just started getting stations here in tampa. I must say, the convenience of pulling up to the pump on high boost and slicks in a racecar and paying 3.25 a gallon is second to none. Its consistency @ 85!% is quite impressive as well. Thorntons ftw
Old Aug 15, 2013 | 08:09 AM
wantboost's Avatar
Who is Mr Robot?
Only if we could run methanol on the street lol. I get 55 gallon drums local for 140.... that 2.80 a gallon!
Old Aug 16, 2013 | 10:27 AM
tepid1's Avatar
FTW has a tough learning curve. If you can afford $100+ for 5 gallons then go for it.
The window of margin on FTW is small. Most have to run rich as hell to keep their motors from blowing apart.
Personally, I'd go with something else.
Old Aug 16, 2013 | 12:33 PM
wantboost's Avatar
Who is Mr Robot?
It just isn't worth the cost imo... if I were bracket racing at the highest level and needed every last ounce of power then sure but when I can get 55 gallons of methanol for 144 local to supplement pump 93.... you do the math
Old Aug 16, 2013 | 01:45 PM
tepid1's Avatar
That's great and all, but to burn methanol completely you need a very good ignition. The OEM Honda stuff ain't gonna cut it.
Old Aug 16, 2013 | 02:58 PM
wantboost's Avatar
Who is Mr Robot?
I'd be using it for my methanol injection system to supplement my main fuel, e10 93 octane... although I have found a few stations that sell ethanol free fuels (not real clear on the advantage of one or the other) although I guess I could try pump 93/methanol blends... just have to find an agent to bind the two together instead of having two different fuels floating around the tank in an inconsistent mixture, like oil and water
Street driving on methanol would require such a loose motor setup and a serious ignition system, not to mention blowby contamination of engine oil from the loose p2w and ring gaps for a methanol motor. also I think I a custom, designated cam profile would be needed not to mention the fuel system modifications needed.
And you can't exactly pull up to a pump to refuel lol
One can dream haha
