fuel feed rom same side as regulator
Old Sep 16, 2008 | 04:52 PM
downeyballz's Avatar
Default fuel feed rom same side as regulator
is it of to run the fule feed to the fuel rail on the same side as the stock regulator? will the rail mounted fpr make you loose too much pressure before the gas gets to you injectors with them being so close?
Old Sep 17, 2008 | 03:41 AM
DaveF's Avatar
Default Re: fuel feed rom same side as regulator (downeyballz)
the regulator isnt just wide open, its there to maintain " a constant " in the system.
Old Sep 17, 2008 | 06:59 AM
Default Re: fuel feed rom same side as regulator (DaveF)
i understand that, so it sounds like this should work. im ust wondering if anyone has ever tried this?
Old Sep 17, 2008 | 09:27 AM
DaveF's Avatar
im pretty sure the gm cars are setup very similar to this. the regulator "hole" is about 3/4 the way down the fuel rail.
Old Sep 17, 2008 | 10:18 AM
im going to try it. i could just let the inectors spray into the air wile connected to the rail to test this system
Old Sep 17, 2008 | 12:12 PM
pgpbubble's Avatar
It works perfectly fine, I ran my old nitrous car exactly that way.
-6AN feed on the driversside, OEM return line, AEM regulator, -4AN feed off the passenger side for the nitrous.
Old Sep 17, 2008 | 03:34 PM
Default Re: fuel feed rom same side as regulator (pgpbubble)
thats what i needed to hear
turboef90
Aug 11, 2013 12:28 PM
BC_Garage
Aug 25, 2012 01:17 PM
zexpoweredem2
Honda Civic (2001 - 2005)
Jan 29, 2007 07:09 AM
baphomet
Oct 4, 2003 08:33 PM
