Frontmount install question
Old Nov 8, 2007 | 11:16 AM
Liquidgsr's Avatar
Default Frontmount install question
I installed my front mount and its hanging damn low. This is a 94 integra GSR. I had to make brackets so it would bolt to the bumper support and it sits under it. Its hanging like two inches below the front bumper. Is that right? Is it suppose to go under the front bumper support or in front of it?
Old Nov 8, 2007 | 11:30 AM
champLSinteg's Avatar
Default Re: Frontmount install question (Liquidgsr)
how big is it?
Old Nov 8, 2007 | 11:43 AM
LSTDB8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">I installed my front mount and its hanging damn low. This is a 94 integra GSR. I had to make brackets so it would bolt to the bumper support and it sits under it. Its hanging like two inches below the front bumper. Is that right? Is it suppose to go under the front bumper support or in front of it?</TD></TR></TABLE>
under the support is correct but any fmic over 7'' tall installed without modifying the support is gonna hang below the bumper i had the same problem my intercooler is 9'' i trimmed off about 2 inches across the support mid section for it to fit right
Old Nov 8, 2007 | 11:46 AM
eh3 93's Avatar
What kind of brackets did you use?
Old Nov 8, 2007 | 12:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Frontmount install question (eh3 93)
more specifically what intercooler is it? where are the inlet and outlets?
Old Nov 8, 2007 | 01:14 PM
Liquidgsr's Avatar
Default Re: Frontmount install question (boostedcivicsir)
wow nice people giving me feed back.
Ok the intercooler is a XS ENGINEERING intercooler off of there power max turbo kit. Ill get the measurments. Inlet and oultlet are on the sides at the bottom. I made brackets for it. It has one flange on each side to bolt up to something and one on top in the middle. I have one picture and its bad but here it is.
Old Nov 8, 2007 | 01:53 PM
NVturbo's Avatar
O.G. triple O.G.
You know you can put the FMIC on the other side so the brackets won't show as bad...unless the inlet and outlet are different sizes. There are simple ways to mount it a little higher than it is already. Use your ingenuity bro.
Old Nov 8, 2007 | 04:30 PM
JaredKaragen's Avatar
you need to cut out the bumper and mount it higher.
Old Nov 8, 2007 | 04:58 PM
Liquidgsr's Avatar
Default Re: Frontmount install question (NVturbo)
the brackets wouldn't align right if i did that. Thanks though. Yeah i dont want to cut the bumper so i guess its gonna have to hang that low.
Old Nov 8, 2007 | 05:29 PM
confucioussae's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">the brackets wouldn't align right if i did that. Thanks though. Yeah i dont want to cut the bumper so i guess its gonna have to hang that low.</TD></TR></TABLE>
Get a different IC. Better now then later, when a speed bump busts open your nice XS one. Don't want to drag that **** over a driveway, now, do you?
Old Nov 8, 2007 | 05:50 PM
Project X's Avatar
I had my rebar removed in order to fit my IC in. Even then, I had to install an ITR lip in order to cover up the bottom part of it.
Old Nov 8, 2007 | 05:54 PM
Tippyman's Avatar
Default Re: (Project X)
Yeah, you just need a bigger lip, lol.
Old Nov 8, 2007 | 07:53 PM
JDMeg95's Avatar
Default Re: (Tippyman)
get a lip
Old Nov 9, 2007 | 12:23 AM
Tony the Tiger's Avatar
Default Re: (JDMeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMeg95 &raquo;</TD></TR><TR><TD CLASS="quote">get a lip </TD></TR></TABLE>
Old Nov 9, 2007 | 08:52 AM
NVturbo's Avatar
O.G. triple O.G.
Just do what Project X did....remove the front bumper support and you should be able to move it up. Even though the brackets don't line up to the radiator support, make a bracket using an "L" brace (found at HOmeDepot or Lowe's). LIke I said...use some ingenuity to make that FMIC work and look good.
Old Nov 9, 2007 | 08:58 AM
thewrai6th's Avatar
I also had to remove the front bumper suport, but then again, this Precision intercooler is huge.
I had to make custom brackets to go from the bumper support bolts to the side of the intercooler. Kind of an L with a twist.
Old Nov 9, 2007 | 09:01 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Frontmount install question (thewrai6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">I also had to remove the front bumper suport, but then again, this Precision intercooler is huge.
I had to make custom brackets to go from the bumper support bolts to the side of the intercooler. Kind of an L with a twist.</TD></TR></TABLE>Nine times out of ten, a FMIC is not going to fit perfectly in a Honda. That's why an installer has to modify or fabricate mounting brackets....no matter what brand FMIC it may be. Remember, when turbocharging a Honda/Acura, there is no such thing as an "EASY" button.
CALC!_JUST_du_IT!
Aug 26, 2008 10:36 AM
bb4 jdm lude
Oct 29, 2007 11:01 AM
fastlude69
Jul 14, 2007 08:49 PM
elitesi8
Sep 22, 2005 06:56 AM
geminis2k
Feb 5, 2004 10:00 PM
