Front Mount Size - Integra - Need Dimensions
Old Nov 18, 2007 | 05:40 PM
Mfoehrkolb's Avatar
Default Front Mount Size - Integra - Need Dimensions
I have 2001 integra, i need the dimensions of a front mount that will fill the entire whole. I don't want any piping or fittings to be showing.
not my car, not the correct year. but that is the front. just in case.
Old Nov 18, 2007 | 06:25 PM
philafelman's Avatar
Default Re: Front Mount Size - Integra - Need Dimensions (Mfoehrkolb)
couldnt you just get out a measuring tape?
Old Nov 18, 2007 | 06:32 PM
.RTErnie's Avatar
Default Re: Front Mount Size - Integra - Need Dimensions (philafelman)
your core wont take up the whole length...you'll need wide end tanks too. I would guess somewhere between 33 and 36 inches
Old Nov 18, 2007 | 07:30 PM
Schister66's Avatar
Man U FTW
What kind of power are you going to make?? I have a CCA Intercooler that fits perfectly IMO...its only good to about 350whp though
Old Nov 18, 2007 | 07:59 PM
m R g S r's Avatar
i loved the way my precision 750hp intercooler looked......you see the endtanks and the couplers thou...part of the couplers at least
Old Nov 18, 2007 | 10:48 PM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">couldnt you just get out a measuring
tape?</TD></TR></TABLE>
--- yes i could, but instead of wasting a couple hundred dollers and being wrong over something small. You and others can just help me out and tell me what they used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">your core wont take up the whole length...you'll need wide end tanks too. I would guess somewhere between 33 and 36 inches</TD></TR></TABLE>
--- ya, im also contiplating on cutting out my front grille. i bought a new front bumper because the last one was cut out for the old intercooler. I want everything to appear stock from the outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of power are you going to make?? I have a CCA Intercooler that fits perfectly IMO...its only good to about 350whp though</TD></TR></TABLE>
--- Between 500-600whp. I plan on having this car to do 11's, daily driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">i loved the way my precision 750hp intercooler looked......you see the endtanks and the couplers thou...part of the couplers at least</TD></TR></TABLE>
--- ya, thats what im trying to avoid. i wanted to try to have a intercooler big enough to fill out the entire gap, capable of my 500-600whp goals, and keep the front grille in.
Old Nov 18, 2007 | 10:55 PM
tony413's Avatar
i agree with RTErine break out the measuring tape size it up and get one made.
Old Nov 18, 2007 | 11:05 PM
bigbadboy's Avatar
look into and see if the precision 850 is any longer than the 750
Old Nov 18, 2007 | 11:07 PM
Schister66's Avatar
Man U FTW
Another option is to contact someone, like SLS, and have them build you an intercooler with custom end tanks to fit your setup...that's probably your best option.
Old Nov 18, 2007 | 11:56 PM
187Chor's Avatar
i got mine off ebay its 29x9x3 its decent workmanship good for 450hp and wil fit nicely under ur bumper with no cutting required
Old Nov 19, 2007 | 12:35 AM
Mfoehrkolb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">i agree with RTErine break out the measuring tape size it up and get one made. </TD></TR></TABLE>
--- Ya, ima look around i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">look into and see if the precision 850 is any longer than the 750</TD></TR></TABLE>
--- I didn't see any of those models on their website. But the ones similar to it, were different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Another option is to contact someone, like SLS, and have them build you an intercooler with custom end tanks to fit your setup...that's probably your best option. </TD></TR></TABLE>
---SLS have a website?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 187Chor &raquo;</TD></TR><TR><TD CLASS="quote">i got mine off ebay its 29x9x3 its decent workmanship good for 450hp and wil fit nicely under ur bumper with no cutting required</TD></TR></TABLE>
--- Pictures of how it fit? Remember, im trying to have the intercooler show but not the fittings etc. "29x9x3" sounds kinda short to me, but if ya have a picture. Show please.
Old Nov 19, 2007 | 01:11 AM
Schister66's Avatar
Man U FTW
Here's their website link...long story short, it doesn't work anymore because of a domain dispute http://www.straightlinespecialties.com/
If you want faster responses, pm PSI2HI...tell him Schister66 sent you
Old Nov 19, 2007 | 01:58 AM
Mfoehrkolb's Avatar
Will do.
--- If anyone has a front mount that fills out the entire gap, fill me in with some dimensions.
--- Also, what makes the intercoolers HP rating? The Size? Density/Properties it's made of?
Old Nov 19, 2007 | 05:15 AM
Schister66's Avatar
Man U FTW
The size of the core dictates is power rating...also the quality of the core. IIRC the core's thickness is the most important dimension.
Most shops that build custom sized IC's will use the top of the line cores available anyway.
Old Nov 19, 2007 | 07:11 AM
jmm96gsr's Avatar
Default Re: (Schister66)
I think that if you want the entire front opening filled by the core, then you would not have enough room for the in/ out on a standard IC because of the curve of the lower part of the front bumper cover. Maybe custom fabbed with them slanted back??
Old Nov 19, 2007 | 07:27 AM
Doostur's Avatar
Dont you think a bunch of people in the forced induction forum would know this?
Old Nov 19, 2007 | 11:08 AM
Default Re: (Doostur)
would the endtanks showing be a problem if your painting it black or somethin?
Old Nov 19, 2007 | 11:41 AM
tegdude227's Avatar
jrc use to make one that filled in the hole bumper. you couldent see any end tanks or anything it looked sweet. he doesnt make them anymore as far as i no try ebay tho there was a few floating around
Old Nov 19, 2007 | 12:04 PM
187Chor's Avatar
Default Re: (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">would the endtanks showing be a problem if your painting it black or somethin?</TD></TR></TABLE>
i painted mine black.. no apparents problems here
Old Nov 19, 2007 | 01:33 PM
bigbadboy's Avatar
my whole IC is painted black and i have 0 problems
Old Nov 19, 2007 | 03:02 PM
chubz0r's Avatar
Default Re: (bigbadboy)
while on this topic, does anybody have any pics of a precision 750 in the bumper of a usdm dc integra?
Old Nov 19, 2007 | 07:30 PM
BoostedJeff's Avatar
Yes it is.
750hp Intercooler (AS1026) 31.5 x 10.3 x 3.5
825hp Intercooler (AS1019) 34.5 x 10.5 x 3.5
The 825hp intercooler should fill that bumper fine. Get out a tape measure, I just have you the easy part.
Old Nov 19, 2007 | 07:54 PM
GT40eg's Avatar
Default Re: (BoostedJeff)
thats the precision 750 intercooler
Old Nov 19, 2007 | 08:02 PM
m R g S r's Avatar
...anyway i had to cut the grill out with my 750hp precision one and that was pretty much pressed up against the rad support......i had the large *** street imports intercooler first, and didnt have to cut the grill out for that, it was tube and fin thou, i wanted a bar and plate so i made the switch...
no logs of IAT's with either however
Old Nov 19, 2007 | 08:03 PM
vtekthis's Avatar
Default Re: (GT40eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GT40eg &raquo;</TD></TR><TR><TD CLASS="quote">
thats the precision 750 intercooler</TD></TR></TABLE>
nice intercooler pipe cory lol
