Front motor mount????
Old Apr 22, 2003 | 07:48 PM
Kwuaymaikrup's Avatar
Default Front motor mount????
I have a DA and it looks like the front motor mount is going to be in the way of the downpipe. Would it be OK to run with out it??? I have seen other cars go without it. What is everyone doing that experiences this problem?
-Ryan
Old Apr 22, 2003 | 08:05 PM
keebler65's Avatar
Default Re: Front motor mount???? (Kwuaymaikrup)
i have always read that the only reason the aftermarket mount kits are ok with 3 mounts are because they are much stiffer than stock. so considering that, i would say you'd probably have to upgrade your other three mounts with polyurethane inserts to stiffen them up. thats just my guess though.
Old Apr 26, 2003 | 11:24 PM
Default Re: Front motor mount???? (keebler65)
Thanks for the info.... Anyone else???
-Ryan
Old Apr 26, 2003 | 11:40 PM
SiR Kid's Avatar
New User
Unless HasPort or somewhere makes a 3 mount kit for your chassis, I'd suggest keeping every mount Honda put on it.
Welcome to the wide world of FABRICATION.
Old Apr 27, 2003 | 12:14 AM
LsTurbo91's Avatar
turn the turbo around, compressor sitting on the passenger's side.
Old Apr 27, 2003 | 05:48 AM
CRX SiR T's Avatar
Default Re: Front motor mount???? (LsTurbo91)
i swapped a motor into my car using the hasport billet mounts. It only came w/ 3 mounts, and it's been holding up fine for about 2 years.
Old Apr 27, 2003 | 05:50 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info.... Anyone else???
-Ryan</TD></TR></TABLE>
3M window-weld. goop this in all of your mounts, and they will be stiffer than most aftermarket mounts
Old Apr 27, 2003 | 05:55 AM
SiR Kid's Avatar
New User
Default Re: Front motor mount???? (CRX SiR T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX SiR T &raquo;</TD></TR><TR><TD CLASS="quote">i swapped a motor into my car using the hasport billet mounts. It only came w/ 3 mounts, and it's been holding up fine for about 2 years.</TD></TR></TABLE>
Try to get on task here. We're talking about a DA TEG, not a bolt in mount kit for a ED chassis. The DA's come with a B series, he just wants suggestions on if he can remove the stock front without issues &lt;doubtful&gt; or if there is a full mount kit or upgrades for his stock mounts.
Old Apr 27, 2003 | 06:56 AM
brekekex's Avatar
Just get the Energy Suspension inserts for the other 3 mounts and you'll be fine.
I ran my DA like that before without much engine movement at all.
Now I am completely deleting the existence of the front mount.
-Tom
Old Apr 27, 2003 | 08:19 AM
Quick 200k Mile Motor's Avatar
I ran without the front motor mount for 2 years. The rear motor mount went to hell and caused shifting problems. And thats with running polyurethane inserts on the right & left mounts <U>but not the rear</U>. The rear wouldn't fit, I still dont know why, aren't all rear mount inserts on DA's the same?
The rear mount takes most of the beating.
If you're going to run without the front, make sure you have some support in the rear ..or else the stock rubber will start to rip.
If mine ripped with the motor only producing 130 ftlbs of torque, imagine the torque beating from FI!
just looking out for my fellow DA's
I'm keeping mine for life.
Old Apr 27, 2003 | 11:00 AM
Default Re: Front motor mount???? (Quick 200k Mile Motor)
Do they make inserts for the two side mounts??? I bought the Energy inserts but it only came with ones for the front and back.......the 3M idea sounds good to me....I wonder if it gets so hard that it would crack though???
-Ryan
Old Apr 27, 2003 | 11:32 AM
FFDragger's Avatar
New User
I've got the same problem man. Prothane makes the inserts for the left, right, and rear mounts. I'll probably do away with the front mount and run the Prothane inserts.
Old Apr 27, 2003 | 11:46 AM
Default Re: Front motor mount???? (FFDragger)
Where did you get the side mount inserts??? Like I said before, I can only find the front and rear inserts.
-Ryan
Old Apr 27, 2003 | 12:28 PM
Tinker219's Avatar
Im telling ya...3M window-weld. Stiff as *****, and I dont see how it could crack/wear.
Old Apr 27, 2003 | 12:36 PM
niedejb's Avatar
Default Re: Front motor mount???? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Im telling ya...3M window-weld. Stiff as *****, and I dont see how it could crack/wear.</TD></TR></TABLE>
I agree
Used it on all my mounts.
Old Apr 27, 2003 | 12:44 PM
Well that looks like what I will be using then....now where do i get this ****???? Home Depot??
-Ryan
Old Apr 27, 2003 | 02:37 PM
Tinker219's Avatar
autozone, advance auto, any autoparts store. Its windshield glue, I think most car manufacturers use it.
SoullessJapaneseMachine
16
Dec 24, 2020 07:11 PM
t0kyoStatus
Mar 6, 2009 11:09 PM
91crxturbo
Jan 10, 2007 08:03 PM
Novtecdohc
Jun 24, 2005 01:16 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
