FPR question...
Old Nov 23, 2002 | 09:07 PM
HondaCutter's Avatar
Default FPR question...
When using the vortech FPR, should a vacuum line still goto the stock FPR or just leave it alone?
Old Nov 23, 2002 | 09:39 PM
Brad's Avatar
Default Re: FPR question... (HondaCutter)
yes a vacuum line still goes to the stock fpr if you're using a vortech fmu, you can tee it from the same manifold source. I think vortech makes fpr's that replace the stock fpr's, but I think your refering to the fmu.
Brad
Old Nov 23, 2002 | 09:43 PM
Default Re: FPR question... (Brad)
what would happen if I didn't put a vacuum line on it? cause I haven't had one on it since I put the turbo on...but I still get good vacuum. but other things are kind of weird.
Old Nov 24, 2002 | 09:45 AM
bump
Old Nov 24, 2002 | 12:34 PM
bumpity bump
Old Nov 24, 2002 | 02:05 PM
SJP0tato's Avatar
All that'd happen is you wouldn't be getting the lower fuel pressure during higher vaccum situations. Pretty much any non-acceleration driving would have a high fuel pressure. It's possible the ecu could correct for the added pressure, but you might as well just T off of another vaccum source & make the FPR earn it's keep.
Ryan P.
Old Nov 24, 2002 | 08:26 PM
Default Re: FPR question... (SJP0tato)
ok, thanks
goingtobefast
Aug 9, 2005 05:56 PM
sohcturbocoupe
Dec 9, 2004 10:09 AM
silver4
May 15, 2004 11:21 AM
DD_JonnyLee
Oct 10, 2002 10:11 PM
SpeedracerS4
Jan 25, 2002 09:47 PM
