foglights possible with intercooler?
Old Apr 3, 2005 | 01:23 PM
Turbo_Mike's Avatar
Default foglights possible with intercooler?
I'm putting a turbo setup together on my crx, and i'm wondering if its gonna be at all possible to keep my uber rare foglights intact.
Old Apr 3, 2005 | 01:25 PM
Turbo_Mike's Avatar
Default Re: foglights possible with intercooler? (razor ron)
The core is 20.5" x 6.0" x 2.75"
Overall lenght is 28"
Old Apr 3, 2005 | 01:37 PM
snoochtodanooch's Avatar
probably not in the stock locations. i know on my 94 without fogs the intercooler piping backs right up against plastic of the bumper cover. I am assuming it would be very difficult to get it to work with the fogs in their also.
Old Apr 4, 2005 | 08:22 AM
Turbo_Mike's Avatar
Default Re: foglights possible with intercooler? (snoochtodanooch)
Old Apr 4, 2005 | 08:35 AM
underpressure02's Avatar
i am running fog lights on my 92 hatch with a drag kit without any problems
Old Apr 4, 2005 | 10:38 AM
Benjithx's Avatar
Default Re: foglights possible with intercooler? (underpressure02)
I had a spearco ic with turbonetics piping that allowed me to install factory fogs on my EM1
Old Apr 4, 2005 | 10:44 AM
BlueShadow's Avatar
I have a Revhard kit for my CRX and it has a backdoor style intercooler. If you use the same type design then you definately wont have to worry about you foglights getting in the way.
Here is a pic. I test fitted the bumper too and I have JDM fogs installed. I think that's the type of foglights, I'm not sure. The previous owner installed them.
http://www.imagestation.com/pi...5.jpg
Old Apr 4, 2005 | 10:52 AM
Turbo_Mike's Avatar
Default Re: foglights possible with intercooler? (BlueShadow)
Hot side is not a back door though is it? Definetly have space on passenger side, but what about driver?
Old Apr 4, 2005 | 11:03 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by razor ron &raquo;</TD></TR><TR><TD CLASS="quote">Hot side is not a back door though is it? Definetly have space on passenger side, but what about driver? </TD></TR></TABLE>
Are you talking about my setup?
Actually I think I worded it wrong. IIRC back door means the piping comes out of the back of the end tank not the sides. The piping going in and out of my IC just make a 90 degree turn, and the core is short enough to where they go through where there are already holes in the frame. I just made the hoels bigger.
Not counting the endtanks and piping my IC core is 22x6.5x3. So maybe you can copy the endtank design and run it like the Revhard. The Revhard kit has the compressor on the drivers side and RH welded an elbow onto my compressor outlet. From the compressor there is a short piece of L shaped aluminum piping (5" x 8") which goes into the IC. Then my piping from the IC outlet to the TB is that one piece that you see in my pic.
EDIT: on the driver side if you copy the RH piping you will be really close to the driver side frame rail. My piping is so close that I will have to install the IC elbow onto the compresor outlet and then mount the manifold up like that. That's how little room I have...with the manifold and turbo installed on the motor I would not even be able to install the small IC elbow, I have to install it onto the mani and turbo then install the whole thing on the motor.
Old Apr 4, 2005 | 11:21 AM
BlueShadow's Avatar
more pics of my RH setup
http://www.imagestation.com/pi...a.jpg
http://www.imagestation.com/pi...c.jpg
Old Apr 15, 2005 | 04:21 AM
pearl's Avatar
i thought i was going to be able to keep mine, but i ended up having to cut out my whole grill. i have a ek though only way to know is install that kit and see what happens, good luck
Old Apr 15, 2005 | 02:56 PM
turbodohcsi's Avatar
i run the large greddy intercooler, and 2.5 inch turbo pipeing and with SLIGHT modification to the fog lights housing, and not using greddys premade mounts, i made mine work. 2000 civic SI with factory fog lights.
BoostnEK6206
14
Feb 21, 2008 08:46 PM
Die-Laughing
34
Apr 4, 2005 08:06 AM
1SlowSi
Jan 14, 2005 08:59 AM
AzntaggeR
Jan 6, 2005 03:46 AM
Fatty_1775
Nov 19, 2002 04:12 PM
