Foam in catch tank?!?!
Old May 24, 2010 | 05:20 AM
thegatekeeper14's Avatar
Default Foam in catch tank?!?!
I understand what the foam is I'm just not sure as too why I'm getting it. It's not under my oil cap and car dosent smoke that much. Is my head gasket gone?
Old May 24, 2010 | 07:40 AM
96 GSR-T's Avatar
Default Re: Foam in catch tank?!?!
pictures are worth a thousand words....
Old May 24, 2010 | 03:10 PM
Turbo-LS's Avatar
your going to get foam, its condensation building up in the tank and mixing with the oil, makes for a messy mixture and thats why drainback catchcan are such a bad idea. imagine all that going back into your motor
Old May 24, 2010 | 03:39 PM
yea that will happen over time, but this is after driving once
Old May 26, 2010 | 02:14 PM
welfarepc's Avatar
sweaty beer can effect, but in reverse.
the reason u see nothing in the engine is because that gets warm enough to evaporate the condensation.
Old May 26, 2010 | 06:20 PM
dosent happen at idle.
Old May 26, 2010 | 07:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
hot oil, + moisture in air, once the can cools down, moisture comes out of the air and clings to the oil. as it airrates from use, the water oil mix turns to a froth.
Old May 26, 2010 | 07:32 PM
Mr. Badwrench
yup./
never had an issue with a recirculating can.
i will never not run a drain back can.
Old May 27, 2010 | 02:54 PM
DeLucia's Avatar
exactly
Old May 27, 2010 | 03:17 PM
well right now i have them spraying into pop bottles.
Old May 27, 2010 | 10:27 PM
rudebwoy's Avatar
have the same problem in the winter and when ever I run E85 for a long period of time, T1 can. it usually clear it self up after a long drive.
Old May 28, 2010 | 07:29 AM
Turbo-LS's Avatar
Are you guys getting that much oil in your cans that you need drain back? I get hardley anything in my can maybe 1/8th of a quart in between oil changes
Old May 28, 2010 | 08:59 AM
keving85's Avatar
It depends on if they are running baffles or reused the stock baffles and where they tapped the valve cover.
Old May 28, 2010 | 10:00 AM
Turbo-LS's Avatar
Very true I have two off the front of my vc works good. I am thinking of upping them from-10 to -16 for better flow without using more lines
EG94dude
14
Dec 19, 2009 09:06 PM
bigsnorlax
Apr 17, 2009 03:10 PM
blu3g
Nov 21, 2008 05:27 AM
Bond
20
Nov 2, 2005 03:12 PM
Web_Head
Nov 4, 2001 12:41 AM
