Flywheels
Old Oct 30, 2011 | 08:40 AM
rich7777's Avatar
Default Flywheels
Just a quick one,
What flywheels are you boosted guys running ?
I'm debating whether or not to run a stock flywheel on my new setup over a light weight flywheel. I'd imagine having a bit of weight there may benefit us boosted guys ?
Thanks for your time
Old Oct 30, 2011 | 10:21 AM
blackeg's Avatar
Default Re: Flywheels
ive been using the factory type r flywheels for the past few years. i think they are around 12lbs, definately lighter than the regular b series ones. i chose them over aftermarket lighter ones due to awesome oem quality. if you look around you can usually find them for between 50 and 100 bucks, i think i got both of mine for 50 or 60 each
Old Oct 30, 2011 | 10:45 AM
Hidenplanvew's Avatar
Stock for boost, it keeps you from droping out of boost
Old Oct 31, 2011 | 03:02 PM
nonpoint986's Avatar
myth.
get a ball bearing turbo and you dont have to worry about "falling out" of boost. besides, a 12.5 lbs act does a good job anyways. even when you add heavier rods and a tougher clutch, its not that big of a difference anyways.
12.5 is what i run
Old Oct 31, 2011 | 03:09 PM
Muckman's Avatar
Moderator in Chief
Flywheel weight has nothing to do with falling out of boost.
I run the Fidanza 7.5lbs flywheel and Im kinda sick of it but I deal with it.
Old Oct 31, 2011 | 05:23 PM
vtecmasta85's Avatar
Well I thought they were 14lbs. But whatever the weight, they sure are an upgrade to the OEM gsr or b16 one. I'm all motor and I like mines. I thought of putting a 10lb one but with the type r one on my setup it revs quickly and I didn't lose ANY torque. So when I hit the gas I'm actually moving somewhere instead of revving and spinning while moving nowhere! Good luck!! ^__^
Old Oct 31, 2011 | 05:37 PM
met's Avatar
met
I am running the comp billet flywheel the 12.5lb. I have a gt35r so ball bearing it doesn't drop out of boost.
Old Oct 31, 2011 | 09:39 PM
smith_cody's Avatar
im using 12.5lb from the last several years those are good
Old Nov 1, 2011 | 12:35 AM
rich7777's Avatar
Thanks for the replies guys. I've got my hands on a stock tyre r flywheel for a good price so i'm just going to use that.
Old Nov 1, 2011 | 03:19 PM
rs250nut's Avatar
Ah bollocks, I just sold a chromoly flywheel for cheap as I replaced it with a os giken twin disc.
bigsnorlax
Jun 1, 2011 06:45 AM
dc2_h2b
Jan 13, 2011 10:11 AM
flangemastermike
Feb 18, 2006 05:20 PM
Sir-Boost-Alot
Oct 29, 2005 07:29 PM
Si2See
Oct 15, 2003 03:10 PM
