flywheel weight
Old Mar 5, 2009 | 10:53 AM
  #26
streetracer6rpt's Avatar
Default Re: flywheel weight
https://honda-tech.com/forums/showth...2499105&page=2
Old Mar 5, 2009 | 10:54 AM
  #27
4drEF's Avatar
Keyboard Humorist
Originally Posted by GoHybrid
i wonder: what if you used a slightly heavier flywheel and had some method of electromechanical control to declutch the flywheel and re-engage it at a more desirable time?
So, say you spend the energy to spin a 20lb flywheel up to 7000rpm and then shift. When you declutch the transmission, the friction and pumping losses in the engine cause it to slow down. When you release the clutch and engage the new gear, you've lost a thousand rpms or more.
What if, instead, the flywheel declutches from the motor at the same time as the transmission clutch? The crankshaft can freewheel within the flywheel hub and has effectively lost 20lbs of rotating mass, so revs fall quickly, BUT the flywheel is still spinning and losing energy at a slower rate. So instead of losing that flywheel inertia to engine losses, you re-engage the flywheel once the new gear is selected and you get a small boost of power as the flywheel energy is dumped back into the drivetrain. You could even add flywheel energy by capturing energy during engine braking.
I've seen the concept before but in the form of a spinning armature used to capture energy during braking, and used to generate current for an electrical motor upon acceleration. This idea would be more mechanically rooted.
I don't know... just pie in the sky but this thread made me think of that possibility.
Sounds like a lot it might create gear loading issues in the transmission.
I would expect broken tranny parts.
Old Mar 5, 2009 | 12:25 PM
  #28
ll3o0sTeD's Avatar
Originally Posted by The sweed
I like the one pice flywheels in cromoly..
i have a 8lb chromoly wheel and its fine for me....i have a garrett t3 42/48 on 15psi...and i have no prob loosing boost between shifts....**** i can get a good third gear scratch to
Old Mar 5, 2009 | 12:34 PM
  #29
Bailhatch's Avatar
You already have the heaviest stock crank and you added heavier rods and pistons. I think the lighter flywheel is a good idea.
I run an itr flywheel right now and it wasn't even noticable compared to the b16 one. My ACT forged chromoly (8lb i think?) is going in soon to help counteract new rods and pistons and a longer stroke crank.
Old Mar 5, 2009 | 01:07 PM
  #30
4drEF's Avatar
Keyboard Humorist
Heavier rods and pistons aren't rotating mass and don't add to the rotating mass inertia.
The crank does, but it's probably negated by the rods and pistons.
Old Mar 5, 2009 | 01:20 PM
  #31
Bailhatch's Avatar
I didn't say rotating mass. They weigh more than stock, so they take more energy to move. I don't see how they would be cancled out by a heavier crank. Adding weight to any moving engine part is using power that could go to the wheels.
Old Oct 6, 2009 | 10:55 AM
  #32
jeryjohn's Avatar
some f1 cars used this system called the KERS system Kinetic Energy Return System....erm system petty cool but the mass required is substantially higher than that of typical flywheel!(
Old Oct 6, 2009 | 10:59 AM
  #33
S2Integra's Avatar
just get it balanced, great idea for engine response on an NA, not really needed with high torque from boosted motor.
EJ8_Man
Honda CR-V & Element
Dec 6, 2015 03:42 AM
ajbucci
May 20, 2006 09:39 AM
Clabbe
Oct 18, 2005 08:22 AM
the.hamburglar
Mar 20, 2005 04:35 PM
Spoold_R
Jan 1, 2002 07:54 AM
