Flooding with uberdata? how did you fix it?
Old Aug 18, 2004 | 10:51 PM
ComputerJLT's Avatar
Default Flooding with uberdata? how did you fix it? also blowing brake fuses - ITS FIXED; READ
UPDATE FARTHER DOWN; IT IS FIXED in case you run into this problem
I have to unplug my fuel pump; get the car to sputter and sorta start then plug it back in and hold the throttle down until the motor decides it wants to run on its own.
I have a Z6 bottom with an A6 head; obd1 intake and obd1 map sensor and a hardwired obd0-obd1 harness for my 90 civic si witha greddy turbo kit. I'm running dsm 450's with my FPR set at 40psi (~30psi @ 20" of vaccum so it's working) and know the injectors work because i ran turboedit on my old a6 obd0 for a long *** time with them running like a champ.
I have tried the beerbongkicksass.bin file it does it; i made a basemap with 1.65r3 1.666 1.7beta and they all do the same thing. All with the enrichments turned to about 50 and enabled.
Now...... every now and then i get a CEL for my intake air temp sensor and i'm thinking it may be fucked or my wiring to it may be having some problems.......
Will the IAT sensor really cause obd1 to freak out and flood the motor like that?
So tomorrow i'm going to grab my trusty multimeter and check the IAT sensor and hope thats fucked; but shouldnt the computer default to something if it is getting a wierd reading or if its unplugged?
Modified by ComputerJLT at 7:53 PM 8/21/2004
Old Aug 18, 2004 | 11:21 PM
reaction360's Avatar
Default Re: Flooding with uberdata? how did you fix it? (ComputerJLT)
does it only do it at cold start? or all the time? also, how does the car run once it's started? (rich?) and have you had the injectors checked out?
Old Aug 18, 2004 | 11:31 PM
Default Re: Flooding with uberdata? how did you fix it? (reaction360)
once the initial stuttering is over the car runs fine;
and i dont have a wbo2 anymore so i dont know how rich its running but it is running rich.
and it'll do it on hot or cold start. and i know the injectors work because i had them running for a long while w/ turboedit. I hope its my IAT sensor.... but i dunno; with my luck it probably won't be.
I'm really starting to hate myself for converting to obd1 :-/
Old Aug 19, 2004 | 12:32 PM
anyone else have an idea?
Old Aug 19, 2004 | 12:33 PM
toolowsol's Avatar
what does the wideband say is going on
Old Aug 19, 2004 | 04:49 PM
Default Re: Flooding with uberdata? how did you fix it? (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">what does the wideband say is going on</TD></TR></TABLE>
dont have on; but i know the car is flooding at startup and running extremly rich
Old Aug 19, 2004 | 05:42 PM
leed's Avatar
A failed IAT can deff cause hot/cold start issues. Usually one or the other, but not both (in my experience) depending if its reporting a grossly cold/hot reading.
When a cel pops for IAT the computer defalts to 120* on the IAT which 'should' allow for both hot/cold starts.
Time to whip out the multimeter.
HTH,
Dave
Old Aug 19, 2004 | 06:36 PM
RudeLude's Avatar
Default Re: Flooding with uberdata? how did you fix it? (leed)
just get access to a wideband and check it out, might be something extremely simple. might show that u actually are just running rich at idle
Old Aug 19, 2004 | 08:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leed &raquo;</TD></TR><TR><TD CLASS="quote">A failed IAT can deff cause hot/cold start issues. Usually one or the other, but not both (in my experience) depending if its reporting a grossly cold/hot reading.
HTH,
Dave
so i guess if you unplug the sensor it should start?
well mine doesn't :-/ it floods with the thing plugged in or not. i guess it may be my wiring. i need to get off my *** and go check that ****; i think i'll do that now
Old Aug 21, 2004 | 04:50 PM
just an update: I fixed it.....
It wasn't my IAT sensor; MAP coolant nothing; it was my ******* conversion wiring. I accidnetly swapped the brake switch wire and the multi-sensor grounds wire :-/
they are both green/white hte only difference is one has silver and one has red dots.
so needless to say the car starts purrs and runs great :-/
I dont know wheather to feel glad that the car works or feel so dumb about overlooking that.
So anyway; in case someone finds this thread and they're burning up brake light fuses and their car is running like **** then check those two wires; you probably swapped them.
Old Aug 21, 2004 | 06:23 PM
glad u found the problem
Old Aug 21, 2004 | 06:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">glad u found the problem </TD></TR></TABLE>
me too :D
Old Aug 21, 2004 | 06:52 PM
Joseph Davis's Avatar
Most people would lack the heart to go over their wiring once they are "so far into it." Good job, every last one of us makes little errors like that, only the hardcore keep working until they figure it out.
Old Aug 22, 2004 | 01:39 AM
Default Re: Flooding with uberdata? how did you fix it? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Most people would lack the heart to go over their wiring once they are "so far into it." Good job, every last one of us makes little errors like that, only the hardcore keep working until they figure it out.
damn right :D
I was about to pull my hair out with this mess :-/ 2 computers; 2 distros; countless hours spent checking wiring (which obviously wasn't thurough enough) and it wound up being 2 swapped wires :-/ oh well we live and we learn
i'm just happy this bitch is up and running again :D
Old Aug 22, 2004 | 04:49 AM
leed's Avatar
Got lucky there, that 'could' have been a real bitch to track down. Nice job.
90vtechatch
Oct 9, 2010 02:41 PM
Bc1r6x
Jan 3, 2007 07:18 PM
na96civic
Jan 16, 2006 07:44 PM
MoNkeyBoY4
Dec 14, 2005 12:39 PM
Exempt
Mar 9, 2005 12:02 PM
