First attempt at a basemap, opinions please
Old Sep 5, 2004 | 09:09 PM
Pfieff's Avatar
Default First attempt at a basemap, opinions please
Giving uberdata a shot so I went ahead and made my first basemap. Setup is:
d16y7 block
d16y8 head
550cc injectors
3 bar
Let me know if there is any other info you guys need. Also, where are you guys setting vtec engagement and disengagement on d16's??
Here's the bin:
http://shns.antsmarching.org/pfieff/base.bin
maps for you lazy folks
low fuel:
high fuel:
low ign:
high ign:
Old Sep 5, 2004 | 09:20 PM
mtber's Avatar
Try the ubberdata forums for a better response...
There actually is some articles which walk you through a basemap setup step by step.
You need to adjust your injector size via the injector calc if you have not already done so...
http://www.ecimulti.org/uberdata/
Old Sep 5, 2004 | 10:20 PM
leed's Avatar
Default Re: First attempt at a basemap, opinions please (Pfieffdog)
Cant give any feedback on the fueling from just the #'s, but your ignition timing seems like a bit much in boost.
IMHO, Id start the car out at 28* max advance at 0" WOT like it is stock, and work your way from there.
This is how I would personally start a base ign map for a D.
Notice how I did the ignition timing around the idle area. I like to do it like this, so you can be 100% sure your dizzy matches your maps when timing it w/ the timing light.
http://host90.ipowerweb.com/~d...d.bin
Old Sep 5, 2004 | 10:23 PM
leed's Avatar
Default Re: First attempt at a basemap, opinions please (leed)
BTW, what C/R are you at? I assume you lowered it to run more boost, given that your on a 3bar?
Old Sep 6, 2004 | 07:32 AM
Pfieff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leed &raquo;</TD></TR><TR><TD CLASS="quote">BTW, what C/R are you at? I assume you lowered it to run more boost, given that your on a 3bar?
C/R is about 9.3:1 and the maps are scaled for 550's or at least I am pretty sure I did it correctly.
Old Sep 6, 2004 | 07:36 AM
TurboJesse
Guest
Posts: n/a
timing in boost is too aggressive for a basemap...27deg @ 9psi is alot. what did you use as your retard per psi?
91tegboi
Mar 18, 2012 02:19 AM
dominidg123
Feb 4, 2010 09:57 AM
1991_HondaAcc
Dec 7, 2009 09:00 PM
jaydim
May 28, 2007 05:16 PM
infinkc
Dec 10, 2001 12:15 AM
