finished my turbo AND???
Old Jan 30, 2004 | 09:25 AM
vtekthis's Avatar
Default finished my turbo AND???
Modified by vtekthis at 8:44 PM 11/22/2007
Old Jan 30, 2004 | 09:43 AM
racinskittle's Avatar
Default Re: finished my turbo AND??? (vtekthis)
did you uplug the ecu or anything when you did it? im curious.
Also, the SRS switch is under your steering wheel. You'll see a small screw holding a cover over it. Take out the screw and make sure the plug is connected.
The yellow plug(male end) should be connected to the yellow clip(female end). If it's not, connect it.
Usually, when unplugging the ecu you want to disconnect the SRS system to prevent it from accidently being "tripped" You do this by taking that same yellow plug (male end) and putting it into the RED clip (female) that's located on the cover(under the steering wheel).
GL
EDIT: OH YEAH BTW, dont lose that screw like I almost did twice, it's really small
Modified by racinskittle at 7:33 PM 1/30/2004
Modified by racinskittle at 7:34 PM 1/30/2004
Old Jan 30, 2004 | 11:46 AM
vtekthis's Avatar
ill try that, but i did diconnect the ecu, would that have tripped the srs system? explain
92b16vx
54
Feb 8, 2012 07:52 AM
bankhead83
10
Mar 26, 2004 02:58 PM
importneeds
May 5, 2002 11:20 AM
2k1TypeR0610
Oct 12, 2001 07:04 PM
