finally boosted!
Old Nov 1, 2003 | 02:42 PM
  #26
Disco Stu's Avatar
Default Re: finally boosted! (ha illuminato un)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">
a/r is .63 and the wheel trim is 76</TD></TR></TABLE>
Damn, I'm assuming you're going to be running BIG numbers later on down the road then? Because I can't imagine how frustrating it must be to have to wait for a turbo that damn big to spool up, just to run 6psi. How is daily driving with that thing?
Old Nov 1, 2003 | 03:21 PM
  #27
Yosshaa's Avatar
awsome! congradulations
Old Nov 1, 2003 | 03:57 PM
  #28
DENCIO's Avatar
Default Re: (ambition)
very nice set up, but where's the dump tube?
Old Nov 7, 2003 | 12:25 AM
  #29
S2KP's Avatar
What are your Safc settings set at? Are getting any detonation up top?
Old Nov 7, 2003 | 04:40 AM
  #30
m R g S r's Avatar
Default Re: (Turbo_Siii)
I am thinking of running the sc61 on a stock b series block. ALOT of people say it's not worth it, but what is YOUR opinion about it? Is it worth the wait for it to spool up, or do you wish that you had purchased a smaller turbo?
Old Nov 7, 2003 | 07:34 AM
  #31
VTC_CiViC's Avatar
Default Re: (m R g S r)
Is it just me, or is your wastegate dump pointing directly at the head.. with no dumptube??
BTW looks like my FMIC
Old Nov 7, 2003 | 04:03 PM
  #32
DownBoyDown's Avatar
Damn, Looks Good! If you dont mind me asking. How much did the setup cost you?
Old Nov 7, 2003 | 04:11 PM
  #33
NuclearB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking of running the sc61 on a stock b series block. ALOT of people say it's not worth it, but what is YOUR opinion about it? Is it worth the wait for it to spool up, or do you wish that you had purchased a smaller turbo?</TD></TR></TABLE>
waiting for the boost isn't bad at all. it's great because under normal driving conditions, no boost, but when i want it, the top end is huge. some times i do wish that i had gone with a smaller turbo, but then i keep in mind that i bought this now so i wouldn't have to upgrade the turbo in about 6 months. i'm planning on hondata s200b, ls/vtec, sleeves, rods, pistons, and valvetrain real soon. i'd say go ahead and get it if you're planning on building up the motor, no point in buying a smaller one now and then getting a bigger one later in my opinion.
btw, i'm pushing .6 bar now...runs great
Old Nov 7, 2003 | 04:12 PM
  #34
Default Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Is it just me, or is your wastegate dump pointing directly at the head.. with no dumptube??
well, i dont have a dumptube and i thought to myself "better the head than my radiator..." is it bad to have it setup that way?
Old Nov 7, 2003 | 04:14 PM
  #35
Default Re: (DownBoyDown)
the whole setup cost me around $3200
Old Nov 7, 2003 | 04:58 PM
  #36
egturbo's Avatar
nice vacuum manifold.. how much u get that for? was it an easy install? u only usin four ports?? where did u get the vacuum source for it?? brake booster?
Old Nov 7, 2003 | 09:27 PM
  #37
Default Re: finally boosted! (egturbo)
the vacuum manifold was built out of a hugh sheet of inch think plexiglass i had laying around. we pressure tested each one at 100 psi with no leaks. vac is run from the fpr.
Old Nov 7, 2003 | 11:11 PM
  #38
DigitalFusion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un &raquo;</TD></TR><TR><TD CLASS="quote">the vacuum manifold was built out of a hugh sheet of inch think plexiglass i had laying around. we pressure tested each one at 100 psi with no leaks. vac is run from the fpr.</TD></TR></TABLE>
how did u seal those fittings in there?
Old Nov 8, 2003 | 01:12 AM
  #39
Default Re: finally boosted! (WebGeek)
silicone and teflon tape
Old Nov 8, 2003 | 01:19 AM
  #40
SiBirdie's Avatar
yah i also wonder.. Is it bad just to leave the dumbtube facing your head openly ? or should to route it down to the buttom ?
Old Nov 9, 2003 | 06:32 PM
  #41
Turbo Laser's Avatar
Default Re: finally boosted! (SiBirdie)
nice setup.....btw how much was just the turbo?
Old Nov 9, 2003 | 07:34 PM
  #42
Default Re: finally boosted! (nocarloser)
art hooked me up with a killer deal on the turbo and manifold package. pm him for prices.
Old Nov 19, 2003 | 10:08 AM
  #43
Echo7847's Avatar
Re-route the dump tube back into your exhaust or out the bottom of the engine bay. The way it is now your bay's gonna be black as hell. It doesnt even look like you have any room to put a dump tube on there @ all.
Old Nov 21, 2003 | 04:04 PM
  #44
superfuji57's Avatar
what fans are you using to keep the a/c?
Nice setup, btw
Old Nov 21, 2003 | 04:08 PM
  #45
Default Re: (superfuji57)
i'm using the stock a/c fan on the passenger side of the radiator. a/c works fine. i was concerned about it at first, but after talking to some of the guys from jotech, they said there shouldn't be any problems, as long as i had atleast one. i figure is the a/c ever goes out, time to get rid of a/c and get a full race mani.
Old Nov 21, 2003 | 04:29 PM
  #46
accordfreak's Avatar
Default Re: (ha illuminato un)
are those gauge holders made out of fiiberglass or plastic? if either, how'd u make the mold? loook great
Old Nov 21, 2003 | 09:27 PM
  #47
T4eg's Avatar
Default Re: (Unseen Harm)
nice setup
let us know some #'s
Old Nov 21, 2003 | 10:01 PM
  #48
{MiKe}'s Avatar
Default Re: (BlueHatch00)
really nice man
Old Jan 2, 2004 | 08:52 AM
  #49
Ri5e's Avatar
Did you ever get the car dynoed? I want to see some dyno numbers with the SC61
Old Jan 2, 2004 | 09:16 AM
  #50
slowguy's Avatar
sweet
