finally boosted
Old Jun 25, 2003 | 01:34 AM
flip1199's Avatar
Default finally boosted
Well i actually finished my setup 2 weeks ago but wtdr wouldn't let me upload pics. What a damn weekend that was. We started at 11:30am friday and finished at 4:30 am on that same saturday. Yes that's 17 straight hours of work. The only break we took was to go buy another air rachet, grinder, cutter from harbor frieght and that's it. But it was well worth it. There was a total of about 8 guys that worked on it through out the course of the day/nite. It would have taken a shorter time but we had to measure/cut/ and weld the pipes. The only problem we ran into was the stock header didn't wanna detatch itself from the rest of the exhuast so we had to cut the damn thing off.
Now time for the pics:
Here's what we started out with
My friend brian who was doin all the weldin for us. (He don't need no stinking gloves )
It was a bitch gettin the turbo to fit
Injector shot
i/c shot
The finished product
The setup:
Revhard mani
t3/t4oe .60trim, .63a/r
spearco i/c
hks bov
tial 35mm w/g .45bar spring
custom i/c pipin
custom 1.5ft long downpipe
Rc 550cc injectors
walbro 255lph pump
hondata s200 w/boost, and 3 step
pr4 ecu
Getting it timed this friday, and dynoed on sunday.
What u guys think???
Old Jun 25, 2003 | 01:38 AM
lazerus's Avatar
Default Re: finally boosted (flip1199)
Sweet!
But be warned, that pipe elbow coming off that turbo will explode, probably while on the dyno or at the track. they dont like heat + pressure at all.
Old Jun 25, 2003 | 01:41 AM
iam7head's Avatar
Default Re: finally boosted (lazerus)
you need silicone hoses mang...
the welding looks good, not bad
hey mang, wrap that freon line or it will catch on fire
Old Jun 25, 2003 | 06:32 AM
SiBirdie's Avatar
Default Re: finally boosted (iam7head)
i got a questino for you..
Since you are running hondata with boost opition is it already tune for your car? Because i have hondata s200 tune for my old all motor set up. And when i purchase a turbo all i need is to get the boost opition with a base program and after that i can run boost ? Cuase you say your car isn't tune so im taking you running your base prelude ecu program with boost opition on hondata right ?
Old Jun 25, 2003 | 07:42 AM
gitwidit's Avatar
Default Re: finally boosted (SiBirdie)
Nice work, spazzi!
Old Jun 25, 2003 | 08:43 AM
redlinegsr's Avatar
Default Re: finally boosted (GITWIDIT)
looks good. let us know what numbers you put down
Old Jun 25, 2003 | 10:10 AM
flip1199's Avatar
yea the rubber hose was a 3 dollar home depot solution until i find a place that sells a 2-2.5in 90 degree elbow. Yea i'm running on a basemap for an ls since hondata hasn't put out an application for prelude ecu's.
Old Jun 25, 2003 | 10:15 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
where did you buy the intercooler piping from?
Old Jun 25, 2003 | 10:16 AM
flip1199's Avatar
Default Re: (v-attack)
jc whitney
Old Jun 25, 2003 | 10:39 AM
psileepR's Avatar
New User
Default Re: (flip1199)
that charge piping is kinda big ?? what is it like 3"
the 90 degree silicone hosing is gonna be $$$
if you are on a budget i recommend reinforced nitrile rubber. cheaper and it can take oil and fuel... while silicone cant .
check out RoadRaceEngineering.com
Old Jun 25, 2003 | 10:56 AM
v-attack's Avatar
is that stuff mandrel bent seamed exhaust pipe or is it aluminum
Old Jun 25, 2003 | 11:13 AM
Boostless97Lude
Guest
Posts: n/a
where did you get the couplings?
Old Jun 25, 2003 | 11:27 AM
symba's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">yea the rubber hose was a 3 dollar home depot solution until i find a place that sells a 2-2.5in 90 degree elbow. Yea i'm running on a basemap for an ls since hondata hasn't put out an application for prelude ecu's.</TD></TR></TABLE>
I was going to ask you about the base map...So how does the ls base map work for ya?
Old Jun 25, 2003 | 11:44 AM
FBP Si 2000's Avatar
Congrats and have fun with it...
Old Jun 25, 2003 | 12:29 PM
ion_four's Avatar
Just find a radiator hose; cheap and can obviously take temp (&gt;200F) and pressure (&gt;1.2atm). Looks good
Old Jun 25, 2003 | 03:15 PM
SiBirdie's Avatar
since i have the hondata s200 i'll just get a boost opition and tell one of the shop that tune hondata to burn me a base boost program like an ITR base program with boost. That mean i wont need to run on a FMU ? and do i still need a missing link and **** like that. If so can you tell me what i need thanx!
nice set up btw i like
ATS*Mark
Mar 31, 2007 06:58 PM
crxforum
May 22, 2005 09:38 PM
thk
Oct 15, 2004 02:38 PM
flip1199
Jun 25, 2003 10:06 AM
