filing my JE piston rings...need help
Old Feb 9, 2004 | 09:55 AM
yusoslo's Avatar
Default filing my JE piston rings...need help
I am getting ready to install my pistons and rods in my block.
Who has filed their rings to the JE spec's
Should I hone the cylinders and then measure the bore with a macrometer, then use that to file the rings
or should I put the ring into the cylinder then measure the gap inside the engine.
I have never done this and have considered having a shop do it, and how much would it cost roughly???
Or is it straight forward and I could do this myself?
This is for JE file fit piston rings on a d16z6
Old Feb 9, 2004 | 10:22 AM
yusoslo's Avatar
Default Re: filing my JE piston rings...need help (yusoslo)
Old Feb 9, 2004 | 10:49 AM
Sonny's Avatar
Put the ring in the cylinder. Push it down about an inch using the underside of a piston (this will allow you to push it down evenly). Then measure the gap.
This is how I did it:
http://www.muller.net/sonny/crx/rings/index.html
My car makes 5000 hp because of it. j/k...but it does run great.
Sonny
Old Feb 9, 2004 | 11:29 AM
Flamenco-T's Avatar
-Install the second ring or even the oil ring on one piston.
-Place the ring that you want to measure on the cylinder, use the top of the piston and puch it down until the second or the oil ring is blocking the piston to goes down further.
You want to use the ring in the piston, so that you will get an even height on the rings down the cylinder.
You can use a file, just makesure to clean up the sharpt edging after you had file it, so that the ring don't get stuck in the groove.
stan
Old Feb 9, 2004 | 02:21 PM
yusoslo's Avatar
Default Re: filing my JE piston rings...need help (Flamenco-T)
ok this explains gapping the rings
what method do I use for filing them according to the bore of the cylinder?
Old Feb 9, 2004 | 02:52 PM
yusoslo's Avatar
bump
Old Feb 9, 2004 | 03:13 PM
Flamenco-T's Avatar
you can either get a ring filer, which is a nice piece of tool and easy to use.
Or you can simply put the ring on a vise and use a file to fiel it down, make sure you file them squaerly and evenly throughut the cut and clean off the rough cut around the edges.
stan
forsakenriceboy86
Nov 29, 2009 09:08 PM
pokmijn
Jul 14, 2007 07:11 PM
PrettyFastRide
Aug 24, 2006 10:24 PM
da_rimrocka
Nov 30, 2005 12:14 PM
riceball777
Jan 17, 2004 09:41 PM
