figure this one out!!
Old Feb 18, 2006 | 07:09 PM
WolfGod's Avatar
Default figure this one out!!
here's my problem, my dipstick is bone ****** dry.. but heres the twist, i have perfect oil pressure, no motor problems, and V-tec even engage's!!! WTF?!??
my car runs perfectly, i build boost perfectly, vtec engages, my pressure gauge reads perfect, i dont get it
Old Feb 18, 2006 | 07:12 PM
EnzoSpeed's Avatar
Default Re: figure this one out!! (WolfGod)
The oil dipstick makes a straight shot down into the oil pan. If the dipstick is dry, the pan needs oil. There's no way around that.
Old Feb 18, 2006 | 07:19 PM
WolfGod's Avatar
Default Re: figure this one out!! (EnzoSpeed)
i know that, and i put in two quarts and its still bone dry, but how could i have perfect oil pressure, my vtec engage, and no motor problems if my dipstick is completely dry??
i know for a fact i have no oil leaks either
Old Feb 18, 2006 | 08:02 PM
grndcont's Avatar
is it possible that the end of your dipstick broke off? i know it's a dumb question, but check it out. you have to check out all the posiblitys. p.s. meby the dipstick tube pulled out of it's hole and is just hanging on.
Old Feb 18, 2006 | 08:10 PM
WolfGod's Avatar
Default Re: (grndcont)
dipstick is complete, i'll check if its pulled itself out of the hole in the morning.. didnt think of that one
Old Feb 18, 2006 | 10:52 PM
komat's Avatar
Default Re: (WolfGod)
do a oil change
and fill it up with 4qts see if it shows up on the dipstick
if it doesnt you probably have the wrong stick for the motor
Old Feb 18, 2006 | 11:40 PM
Tornadom's Avatar
It baffles the mind. Probably something with your stick. Do you have the stock oil pan, or an aftermarket one?
Old Feb 19, 2006 | 01:33 AM
4rc-fed's Avatar
Default Re: figure this one out!! (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">It baffles the mind. Probably something with your stick. Do you have the stock oil pan, or an aftermarket one?</TD></TR></TABLE>
Stock or aftermarket shouldn't matter
Old Feb 19, 2006 | 04:27 AM
TurboCoop's Avatar
Default Re: figure this one out!! (4rc-fed)
Just drain the oil, put in however much is reccomended. I dont know what motor you have but its like 4.3qts for a B-series or 4 for D-series, and if it still doesnt show up you must have the wrong dipstick????
Old Feb 19, 2006 | 06:22 AM
93supercoupe's Avatar
Default Re: figure this one out!! (TurboCoop)
this thread is sweet.
He probably blew the dipstick and its tube out of the motor with all the blow by he has
Like dsm's do with moderate power.
Old Feb 19, 2006 | 06:35 AM
The Weather Man's Avatar
What program are you using for tuning?
It is possible that you disabled the vtec oil pressure switch - meaning it'll come on no matter what the oil pressure is. Just a possibility.
Old Feb 19, 2006 | 06:52 AM
WolfGod's Avatar
Default Re: (TheKINGPin)
i know i have the right dipstick, because it's read perfect untill now, belive me im not that stupid
no i didnt blow the stick or the tube out with any blow by, everything is normal
im useing hondata S200 for tuneing
and dsm's dont blow the dipstick, i had a 400HP dsm and never had a single problem with the dipstick
and i also know for a fact that the oil pressure switch is not disabled because it's cut out on me before when i was low on oil
Old Feb 19, 2006 | 06:57 AM
EK_GSR's Avatar
DO AN OIL CHANGE, and see how much oil comes out, and then fill it up with 4 quarts and see if it registers... thats the solution, stop trying to come up with rocket science.
Old Feb 19, 2006 | 07:06 AM
WolfGod's Avatar
Default Re: (EK_GSR)
you pay for my $30 worth of oil then
Old Feb 19, 2006 | 07:31 AM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rc-fed &raquo;</TD></TR><TR><TD CLASS="quote">
Stock or aftermarket shouldn't matter </TD></TR></TABLE>
I was thinking that a larger capacity, after-market oil pan might have enough oil for everything to work fine, and still not register on the dip-stick.
Old Feb 19, 2006 | 07:32 AM
T3T495GSR's Avatar
Why is this thread in forced induction?
Old Feb 19, 2006 | 07:40 AM
WolfGod's Avatar
Default Re: (T3T495GSR)
because it's a boosted motor? figured i'd put it here because maybe someone with a turbo setup has had a similar problem
Old Feb 19, 2006 | 08:09 AM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">What program are you using for tuning?
It is possible that you disabled the vtec oil pressure switch - meaning it'll come on no matter what the oil pressure is. Just a possibility. </TD></TR></TABLE>
If the motor does not have oil pressure It physically can not go into vtec regardless of the pressure switch ...it uses oil pressure to lock the rocker arms.....if theres low pressure it wont be able to lock the rocker arms any wya you put it.......
from the lower to the upper dot on the dip stick should be one crt of oil....the motor holds 4...if it has 2 it will still have oil pressure.....
you have the wrong length dip stick for a different motor or you have a problem...this isnt a very complicated problem
Old Feb 19, 2006 | 08:10 AM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WolfGod &raquo;</TD></TR><TR><TD CLASS="quote">you pay for my $30 worth of oil then </TD></TR></TABLE>
lol pay for oil or pay for a new motor and turbo
Old Feb 19, 2006 | 08:20 AM
Turbocivic94's Avatar
Come to my job and I'l give u oil cheap bastard
I cant believe u drive boosted car
Thanks. Didn't know that.
I think the most logical thing to do is drain the oil.........
Old Feb 19, 2006 | 08:28 AM
WolfGod's Avatar
Default Re: (Turbocivic94)
you'll give me oil worth ****, i dont put cheap crap in my car
and honestly i dont care if i blow the motor or turbo right now anyway, i got a new motor and turbo on the way, i just wanted to find out what the problem was
yes i drive a boosted car, deal with it, i've been driveing boosted car's ever since my third car
and like i said before, i have the right dipstick so thats not the problem, and i've had my motor cut my vtec before when i was barely over a quart low so obviously i must have good oil pressure
Old Feb 19, 2006 | 08:44 AM
purpleh22's Avatar
Some aftermarket dipsticks, like str, are difficult to read (oil doesn't show) especially when the oil is new/clean. - - good luck
Old Feb 19, 2006 | 08:47 AM
WolfGod's Avatar
Default Re: (purpleh22)
motor is completely stock beside's turbo, stock dipstick, stock oil pan, stock internals, etc, so the dipstick or pan is not an issue
Old Feb 19, 2006 | 08:55 AM
exotik4doorcivic's Avatar
i know this will sound dumb but make sure your on a flat srface and make sure your engine is turned of because if the engine is running it will read diff.
if you did all this drain the oil, you dont have to replace the oil just drain it check how much you have and then put it back in.
