FI -> NA ...... what do u do with the oilpan ? PLUG ???
Old Jul 23, 2004 | 08:14 PM
jEE's Avatar
jEE
Default FI -> NA ...... what do u do with the oilpan ? PLUG ???
I am currently in the process of selling my turbo kit, and i was wondering since i have tapped a hole in my oil pan, is it possible some how that some one sells a custom rubber plug that might fit the hole ? it's only a 3/4" or 1/4" diamter i think.
What should i use to plug it ?
Has any one done this ?
Thanks
Old Jul 23, 2004 | 08:16 PM
StolenTeg's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (jEE)
can it be weld???
Old Jul 23, 2004 | 09:47 PM
m R g S r's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (StolenTeg)
Your talking about where the oil drain was? Did you have an AN or standard sized fitting in there? If you did, they make plugs for the threaded holes.
Old Jul 23, 2004 | 10:06 PM
Alchemist's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (m R g S r)
Flamenco-T sells a cap that caps off the -10an fitting.
Old Jul 24, 2004 | 03:51 AM
jEE's Avatar
jEE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Your talking about where the oil drain was? Did you have an AN or standard sized fitting in there? If you did, they make plugs for the threaded holes. </TD></TR></TABLE>
I am talking bout the oil return from the turbo to the oil pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist &raquo;</TD></TR><TR><TD CLASS="quote">Flamenco-T sells a cap that caps off the -10an fitting.</TD></TR></TABLE>
Is it like a rubber cap ? does it seal properly ? Any body use it before ? Any pics ?
Old Jul 24, 2004 | 05:35 AM
Adriano's Avatar
the plugs are usually aluminum, steel, or brass. They will screw right in.
Old Jul 24, 2004 | 05:50 AM
Rory Breaker's Avatar
Yep, they are metal caps. It will screw right on over the fitting in the pan.
Old Jul 24, 2004 | 06:15 AM
hatchattak's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (newgsrdriver)
sell yours then get the other person's stock
Old Jul 24, 2004 | 06:55 AM
SOHC_MShue's Avatar
my friend actually just ziptied his return line up somewhere in his engine bay and plugged that up. Looks ghetto as ****
Old Jul 24, 2004 | 07:03 AM
david@didrace.com's Avatar
Old Jul 24, 2004 | 07:39 AM
Teg4e's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">my friend actually just ziptied his return line up somewhere in his engine bay and plugged that up. Looks ghetto as **** </TD></TR></TABLE>
LOL.
Yeah, talk to Flamenco-T about it, he'll take care of you.
Old Jul 24, 2004 | 09:04 AM
integra-modder's Avatar
Default Re: FI -> NA ...... what do u do with the oilpan ? PLUG ??? (Teg4e)
This is avaliable from summit racing for 4.50
Project_EK
Jul 11, 2016 06:32 AM
beaterman
Oct 14, 2007 08:12 PM
zerovandez
Aug 5, 2006 05:42 PM
sk8shorty012
Jul 17, 2006 02:10 PM
SiB16A
31
Mar 19, 2005 04:33 PM
