A few ?'s
ok, dont flame me if i sound like a newbe. i swaped a b20 into my LS and now i want boost. i planned on getting an HKS t25 manifold and using a 1G DSM 14B turbo. now
lets say im running 10 PSI on the 14b
lets say youre running 10 PSI on a t3/t4
with all things the same (same fuel, same DP and exhaust, same IC and charge pipes), would the t3/t4 be faster?
and also i was planning on using the 1g DSM injectors because theyre 450 CC stock. i heard you have to use a resistor box out of an 88-91 civic. anyone know how to rig this?
Absolutely!
With regards to the resistor, this is a common install, do a search or check out this address http://www.hondata.com/techinjectorwiring.html
Good luck
Good luck
so when people say its alrite to run about 10 PSI on a stock block b20, it varies with the turbo?
Stopsign32v
Nov 12, 2010 09:22 PM
axxicution
Nov 24, 2007 07:45 PM
blazin
Oct 10, 2004 04:37 PM
