Ferrea valve spring clearance
Old Sep 20, 2014 | 09:26 AM
thermal's Avatar
Default Ferrea valve spring clearance
I've searced and unfortunately Ferrea is closed on weekends for tech assist....
So I'm in the middle of rebuilding my ITR Head with a complete Ferrea Competition Plus valve train. For those of you have done this before, did you have to shave areas in the head to improve clearance between the valve springs and some corners in the head??... After I installed the first 2 exhaust valves/valve springs, I noticed that there is barely any clearance. Comparing the OEM and the Ferrea Comp plus valve springs side by side, Ferrea seemed to be bigger in diameter.
I verified my part numbers and they are correct.
Thank you for your time.
Old Sep 20, 2014 | 09:58 AM
Dark_Teg's Avatar
Default Re: Ferrea... Head Builders chime in pls!
This is common. We had to clearance my head here and there as well.
Old Sep 20, 2014 | 10:52 AM
thermal's Avatar
Thanks
Old Sep 21, 2014 | 09:46 PM
wantboost's Avatar
Who is Mr Robot?
Yea having to remove a bit of material here and there won't hurt... although at high rpm the springs shouldn't grow from harmonics too much, at least if you are within the limits of the springs as far as rpm and cam lift are concerned
Old Sep 22, 2014 | 02:55 AM
1HGEJ2's Avatar
please contact ferrea
Old Sep 25, 2014 | 06:21 AM
thermal's Avatar
I've contacted Ferrea. They recommend not to shave anything.
Thanks everyone!
Old Sep 25, 2014 | 10:15 AM
Dark_Teg's Avatar
Default Re: Ferrea valve spring clearance
There are other threads on this issue if you look. Its a pretty common practice to have to make clearance here and there. My machinist and I decided to remove some material just for piece of mind but I doubt it would hurt anything to leave it as-is.
State.of.Prime
Oct 17, 2010 01:43 PM
ITRiWISH
Jul 12, 2008 10:38 AM
Fallen86
Jul 11, 2006 07:49 PM
danthemang3
Jan 16, 2006 06:02 PM
sleepin91teg
Jun 20, 2004 05:34 AM
