external wastegate size question
Old Jan 26, 2003 | 10:22 AM
Optiks.'s Avatar
Default external wastegate size question
i want to run an external wastegate so i can experiment with some diesel truck turbos i am going with a tial most likely but should i get a 35mm or a 40mm?
BTW this is a '90 talon tsi
Old Jan 26, 2003 | 10:24 AM
Phoenix GSR's Avatar
Default Re: external wastegate size question (Optiks)
that all depends on how much bost/power you plan on making
I think that on <400 hp systems the 35 mm will be fine, higher output will prolly require the 40.. but if you have to have the flange made anyways, why not just get the bigg one for a couple extra bucks, then ou know it will work...
Old Jan 26, 2003 | 10:25 AM
Optiks.'s Avatar
Default Re: external wastegate size question (Phoenix GSR)
i will be making the mani anyways so i will fab a flange for whichever one i go with
Old Jan 26, 2003 | 10:35 AM
dmotoguy's Avatar
which diesel turbos are you going to be experimenting with, do you mean ford/dodge/chevy diesel or Frieghtliner/kennworth/peterbuilt diesel... cause if you have ever seen the turbo off of a big truck (frieghtliner) you will then see that there is no chance on any type of import with less than a 6 litre motor
Old Jan 26, 2003 | 10:39 AM
Optiks.'s Avatar
Default Re: external wastegate size question (dmotoguy)
im talking bout pick ups not 18 wheelers lol
Old Jan 26, 2003 | 02:06 PM
BudaKai's Avatar
Need to fab up a compressor seal so it does squirt oil into your engine.
Old Jan 26, 2003 | 02:15 PM
lazerus's Avatar
Default Re: external wastegate size question (tzsir)
just go with a 40mm so you don't have to mess with it.
Old Jan 26, 2003 | 02:35 PM
Optiks.'s Avatar
can u get a little more detailed about this ?
sxysweed
Feb 6, 2011 09:52 AM
rorik
Jan 18, 2008 08:41 PM
VTteg
Mar 7, 2006 06:45 AM
ineedhelp
May 15, 2005 11:14 PM
TurboLSVtecTeg
Aug 30, 2004 08:59 AM
