external wastegate question
Old Dec 29, 2002 | 03:31 PM
Optiks.'s Avatar
Default external wastegate question
i have a question about external waste gates and waste gates in general, when a turbo has an internal wastegate such as mitsubishi 16g's and you can control when they open with an MBC correct ? but when you have an external wastegate, is there no need for an MBC? because i hear all this stuff about spring pressures in the waste gate, for example if I specify the spring to be at 10psi then is that the same as setting your MBC to actuate the internal gate at 10psi? IF i get a wastegate with a certain psi spring , i cant boost higher then that until i replace the spring in the wastegate? am i understanding this right ?
Old Dec 29, 2002 | 03:42 PM
rjardy's Avatar
Default Re: external wastegate question (Optiks)
You can still run a BC with the external. the BC will manipulate the signall that is sent to the wastegate and open it at the desired time specified with the BC. Get it?
Rob
Old Dec 29, 2002 | 04:00 PM
Optiks.'s Avatar
Default Re: external wastegate question (rjardy)
oh ok i get it now so it really doesnt matter what spring i get if i will be using an mbc i can bost up to like 30 psi if i wanted with a 9 psi spring but the mbc wouldent let the WG know until 30 psi then it would send a signal ok i get it now thanks for the help
Txdragon
Feb 24, 2018 03:03 AM
SOHCDseries
Sep 25, 2011 05:54 PM
touandcim
Mar 3, 2008 07:07 AM
donpeters
Aug 7, 2003 10:15 PM
