external wastegate and o2 sensor question.
Old Nov 4, 2005 | 06:08 PM
JSPECSIR's Avatar
Default external wastegate and o2 sensor question.
does it matter if your o2 sensor doesnt have all the exhaust go past it? ie. exhaust going out the external gate. will it think you are running lean because you dumping some exhaust out and the ecu doesnt know it. this may be a stupid question but im curious.please explain your answers
Old Nov 4, 2005 | 06:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: external wastegate and o2 sensor question. (5THGENSI)
you would think it does, but my wideband doesnt change at all. it measures the oxygen available in the outgoing exhaust. therefore if the exhaust goin out of the dump tube has the same oxygen content, it shouldne matter.
Old Nov 4, 2005 | 07:44 PM
Blackack26's Avatar
Default Re: external wastegate and o2 sensor question. (boostedcivicsir)
Also, your ECU doesn't read the o2 sensor when at full throttle, which is the time where the most exhaust gas is exiting through the wastegate.
Bartman201
Apr 14, 2011 09:54 AM
Bizarre
Jul 9, 2007 02:17 PM
SiR HatchAlot
Apr 11, 2005 06:59 PM
scartail
Oct 16, 2004 05:57 PM
EK45VTi
Jul 31, 2003 12:47 PM
