explain load for me
Old Jan 30, 2003 | 08:35 AM
Boltz's Avatar
Default explain load for me
thanks
im confused about load, anyway i think its load... just never understood a few thangs..
why does a car not build boost in neutral?
why does a highboost car boost more in higher gears than lower gears?
why does the vtec kick of jun3's or toda c's only felt in gear? if you rev the car in neutral just as slow you wont hear as loud of a vtec crossover....
anyways, if you guys could help me out im just curious about this
thanks again
Old Jan 30, 2003 | 08:36 AM
Boltz's Avatar
Default Re: explain load for me (Civic420)
ttt
Old Jan 30, 2003 | 09:04 AM
Scott - 93HB Si's Avatar
Sure it can.
Spool time.
Resistance against the motor = load!
Old Jan 30, 2003 | 09:07 AM
Boltz's Avatar
Default Re: explain load for me (Scott - 93HB Si)
Sure it can.
Spool time.
1st - there was just a big topic about this, and people said that the car should not build boost in neutral (not over 2-3psi)
2nd - spool time doesnt make much sense to me either, shouldnt 8k rpm produce the same boost levels regardless of the gear???
i need more in depth info please and thanks
Old Jan 30, 2003 | 09:09 AM
sgT's Avatar
sgT
builds more boost in higher gears because the engine cannot accelerate as fast
which gives boost time to build up
you wont notice vtec sitting still because unless you have a vtec controller vtec
wont even activate
Old Jan 30, 2003 | 09:35 AM
Boltz's Avatar
Default Re: explain load for me (sgT)
thanks sgt! those are the answers i was looking for
Old Jan 30, 2003 | 10:01 AM
ricodemus's Avatar
yep, a pre-requisite for vtec activation is a vehicle speed of 20mph I believe on my pw0 ecu.
eg:R
Engine Management and Tuning
Feb 10, 2012 11:09 AM
azandford
12
Nov 8, 2009 02:58 PM
motormike40
Sep 27, 2006 01:10 PM
KJ
Jul 13, 2001 05:51 AM
