Experience with Endyn stepper pulley with JRSC?
Old Jul 31, 2003 | 08:01 PM
MADEINIRAQ's Avatar
Default Experience with Endyn stepper pulley with JRSC?
Has anybody used the Endyn stepper pulley with their JRSC? any problems with belt slippage?
also.. stock JRSC boost is 5psi correct? so with the stepper pulley it will jump to 8
Old Jul 31, 2003 | 09:09 PM
1strdko's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (madeiniraq)
Ive used the upgrade pulley from JRSC and made 11 psi of boost.
Anyone use the CRV pulley on a stock B16?
Old Aug 1, 2003 | 07:28 AM
MADEINIRAQ's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (1strdko)
bump. How much boost does a crv pulley yeild on an otherwise stock JRSC
Old Aug 15, 2003 | 04:20 PM
TOFU.man's Avatar
I got 10psi out of my crv crank pulley.
Old Aug 15, 2003 | 04:39 PM
ATgrills.com's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (B16AHondaSi)
i got 9.5 with a crv on a type R
Old Aug 16, 2003 | 05:24 AM
GreddySi99's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (ATgrills.com)
I would NOT buy the endyne pulley because of fitment issues if you want a pulley that fits right with no hassles and comes with the proper size belt then I would get this from motorvations motorsports. Jim is the owner and all he does is specialize in JRSC tuning and parts. here is his #205-661-3600 he will help you out and answer your questions. also if you were to have a problem he would take care of you rather than saying well it should of fit and tough ****
Old Aug 16, 2003 | 07:10 AM
Rory Breaker's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (intercooledJRSC)
Exactly...the MVM pulley is a much better fit, and was designed to eliminate the slipping issues associated with the Endyn pulley. Definitely give Jim a call....his customer service is outstanding as well, as he is ALWAYS willing to help you with any problems you may have. Good guy to know
Old Aug 16, 2003 | 07:33 AM
illi Adik's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (newgsrdriver)
Go Jims MVM...I know I am and currently I have the ENDYN on my car, slip city. The ENDYN has caused me nothing but headaches.
Old Aug 16, 2003 | 08:15 AM
MADEINIRAQ's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (Jackson4Door)
thanks a lot exactly the info i was waitin for.
what makes the mvm pulley better so much better. anybody using this pulley?
does it overdrive 12% or whatever to give ~3psi?
Old Aug 17, 2003 | 07:31 AM
First off, it actually fits, unlike the Endyn which sometimes only has 2 threads to grab onto. The poor fitment has actually caused a few people to experience the pulley flying off under boost...which obviously is ridiculous.
In terms of slipping, I know Endyn supposedly used some "coating" on the pulley to prevent slipping, and when this coating came off, its history. Who knows if thats even true. The MVM pulley was designed to resist slipping naturally, as a larger stepper surface will increase contact area and therefore decrease slipping. Thats how I understand it...Im sure Jim can go into more detail.
Old Nov 21, 2003 | 05:13 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">I would NOT buy the endyne pulley because of fitment issues if you want a pulley that fits right with no hassles and comes with the proper size belt then I would get this from motorvations motorsports. Jim is the owner and all he does is specialize in JRSC tuning and parts. here is his #205-661-3600 he will help you out and answer your questions. also if you were to have a problem he would take care of you rather than saying well it should of fit and tough ****</TD></TR></TABLE>
thanks for the good info
Old Nov 21, 2003 | 05:24 AM
Jonny Black's Avatar
Default Re: Experience with Endyn stepper pulley with JRSC? (JICEK9)
endynes..is 12%
MVM...is 17%
worked great for me
Riptide101
Oct 4, 2017 08:26 AM
i-VTEC_do_you
Jun 3, 2011 07:36 AM
ty521825
Jun 18, 2009 12:22 AM
mrx
Jul 12, 2006 06:30 AM
Rob G
Sep 25, 2004 07:34 PM
