exhaust size piping. And Injector sizing.
Old Jul 9, 2004 | 06:43 AM
mikecivichb's Avatar
Default exhaust size piping. And Injector sizing.
Will I feel a big difference in spool up time and power If I switch to a 3inch exhaust. Im only runnin 7psi. Also I can get dsm 450s for free. Will it be ok to run them on 7psi? Or is it so much overkill the car would be slower. Thanks
Old Jul 9, 2004 | 06:44 AM
Default Re: exhaust size piping. And Injector sizing. (mikecivichb)
Oh yea I have a skunk 2 2.5 inch exhaust now.
Old Jul 9, 2004 | 07:35 AM
ttt
Old Jul 9, 2004 | 07:39 AM
B00ST2nR's Avatar
Default Re: (mikecivichb)
goin from 2.25" exhaust to 3" exhaust will make a noticeable difference.
Old Jul 9, 2004 | 07:45 AM
Default Re: (B00ST2nR)
I have 2.5 now. So you would recommend it? I was going to a turbo apexi n1 Muffler and get a 3inch piping. Also does anyone have any input on the injectors? Thanks
Old Jul 9, 2004 | 08:05 AM
B00ST2nR's Avatar
On a Turbo setup, the exhaust system is Very important. The larger the piping the better it will flow and the more power you'll free up.
As for injectors, which ones are you running? Stock injectors?
Old Jul 9, 2004 | 08:37 AM
No im running prelude injectors. And I want to upgrade to a bigger injector.
Old Jul 9, 2004 | 10:51 AM
Chillin94hatch's Avatar
The question is what kind of motor do you have? As far as an exhaust system goes, piping size is critical with issues of back pressure. In my 94 cx hatch, I have a sohc vtec, soon to be boosted. My exhaust piping is going to be 2.5" and I have dsm 450's.
Old Jul 9, 2004 | 10:56 AM
Default Re: (Chillin94hatch)
I have the d15b2 with a mpfi conversion. Its in a 89 civic hatch dx. All I want is to run 7psi. I was thinking of trading the 450's and just get 370 dsm's. Thanks for your imput So I still dont know about the exhaust though.
Old Jul 9, 2004 | 11:02 AM
Sounds reasonable, good luck, and enjoy the boost
Old Jul 9, 2004 | 03:38 PM
I was always under the impression that you dont want back pressure on a turbo car.
Old Jul 9, 2004 | 09:34 PM
Tchleung's Avatar
Correct. That's why he said: "piping size is critical with issues of back pressure" issues as in. bad thing
Old Jul 9, 2004 | 09:52 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikecivichb &raquo;</TD></TR><TR><TD CLASS="quote">I was always under the impression that you dont want back pressure on a turbo car.</TD></TR></TABLE>
correct time to upgrade
Old Jul 9, 2004 | 10:03 PM
pete98m3's Avatar
2.5" will do fine on a d15 with only 7 psi.
3" would be better but you gotta question at that horsepower level is the additional cost and noise really worth it.
Old Jul 9, 2004 | 10:07 PM
adeihl's Avatar
Default Re: (pete98m3)
isnt there an exhaust gas velocity you want to keep? Going to large an exhaust for to little boost can compromise performance too.
Old Jul 10, 2004 | 12:21 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pete98m3 &raquo;</TD></TR><TR><TD CLASS="quote">2.5" will do fine on a d15 with only 7 psi.
3" would be better but you gotta question at that horsepower level is the additional cost and noise really worth it. </TD></TR></TABLE>
took the words out of my mouth
2.5 is enough even for my 2.3L at 8-10 psi
notice i have apexi RS(zero mufflering material) with no resonator
Old Jul 10, 2004 | 04:25 AM
No I guess it isnt worth it thanks alot for the tech tips.
88 EF Hatch
Aug 11, 2011 01:47 PM
!!miguel!!
Nov 23, 2009 09:06 PM
b18sihatch
Apr 26, 2006 09:16 PM
da9pwnsu
Oct 14, 2005 12:31 AM
DA MUGEN 1
Mar 30, 2003 10:46 PM
