Exhaust manifold
Does anyone know how much it costs to fabricate a custom exhaust manifold and turbo-back piping? I'm thinking about getting the GReddy turbo kit for the GSR and making it fit an LS. That's all I would need, correct? Would there be problems with durability?
all you would have to do is use the manifold and adjust one pipe on the upper intercooler section. The manifold is easy.
[Modified by b18bturbo, 4:27 PM 9/26/2001]
you can use the Greddy manifold and the piping. You just need to modify the upper pipe going to the TB. The LS Tb sits a few inches higher. You'll also need to use an FMU and fuel pump. as far as I know the blue box wont have the correct fuel curve for an LS, it might not even work on the LS.
