exhaust leak
Old Aug 4, 2003 | 04:45 PM
MI4eg's Avatar
Default exhaust leak
well i start up my car today and its so loud, im wondering what the hell??? So im drinving and i can smell exhaust and also no boost..just goes up to 0 and stops.. i check the piping..that is ok. so then i check all the bolts and they are tightened..i think i may need to retighten the wastegate. I was wondering if you blow the wastegate paper flange thingy(that goes in between wastegate and manifold) will that caues your car to sound like you are leaking exhaust?? i know im leaking exhaust just need to find where...well maybe you guys could help me out.
Old Aug 4, 2003 | 05:24 PM
spike's Avatar
Default Re: exhaust leak (MI4BUILT)
Yeah man.. a leaky wastegate gasket will do you in.. happened to us before.. make sure you use lock washers on those bolts for the wastegate.. and use a fire-ring gasket if you can.. roadrace has them (roadraceengineering.com).. good luck!
Old Aug 4, 2003 | 05:41 PM
LJR-LUDE01's Avatar
check the bolt that hold the manifold to the block tony.
Old Aug 4, 2003 | 05:51 PM
LiLOtaku's Avatar
if your downpipe doesn't have a flexpipe, check the seems around your flange that connect to the turbine housing. your welds might be fux0r3d
Old Aug 4, 2003 | 06:13 PM
Mase's Avatar
Default Re: exhaust leak (LiLOtaku)
i used to not use a wastegate gasket, it never leaked without one.
lo0nY
Oct 31, 2007 03:48 AM
tweekerz
Jan 25, 2007 08:15 AM
hotimportcrx
May 21, 2005 03:10 PM
cajnatc
May 11, 2003 10:59 AM
