Is this exhaust housing junk?
Old Oct 3, 2004 | 09:17 PM
5thgencivic's Avatar
Default Is this exhaust housing junk?
I bought a T3 turbo and it has a crack down the middle on the inside of the housing. Can it be used? Here are the pics. Thanks.
Old Oct 4, 2004 | 06:57 AM
Default Re: Is this exhaust housing junk? (5thgencivic)
bump
Old Oct 4, 2004 | 07:09 AM
tgreaves's Avatar
From the pics you have its kinda hard to tell where the crack is.. Can you take another pic of the entire housing and show where the crack is at?
Old Oct 4, 2004 | 07:20 AM
Default Re: Is this exhaust housing junk? (tgreaves)
Old Oct 4, 2004 | 07:26 AM
tgreaves's Avatar
Err.. Thats crack is in an important place.. You can try welding it but that probably would restrict flow unless you grind it down(which is going to be hard because of where its at)..
I would just look around for another exhaust housing that matches your and bolt it on..
Old Oct 4, 2004 | 07:30 AM
Damn. Another reason not to buy used turbo's online unless you really know the person..
Old Oct 4, 2004 | 07:39 AM
tgreaves's Avatar
Where did you get the turbo from.. And also can you take a pic of the entire exhaust housing.. A friend of mine has an extra T3 housing that might fit yours.. What brand is yours?
Old Oct 4, 2004 | 07:43 AM
Got it off a guy on HMT. It's has a 5 bolt discharge pattern and was off of a T-Bird. the .60/.48. I'm probably just going to look for a .63 housing or somethin.
Old Oct 4, 2004 | 07:45 AM
tgreaves's Avatar
If its a .48 exhaust housing then the one my friend has will probably work for you.. He cant use it so he would probably sell it pretty cheap.. I can take lots of pics of it if your interested..
Old Oct 4, 2004 | 08:45 AM
green_GSR's Avatar
You can try to weld the crack, but welding on cast material won't last you very long. I think the housing is pretty much junk.
b20sedan
Oct 23, 2014 12:18 PM
JShull
Sep 28, 2008 01:26 PM
Topdawgg
Oct 27, 2007 12:08 PM
95GSRTT
Mar 31, 2007 11:03 PM
lsvtec101
Apr 8, 2003 12:43 PM
