Engine troubles...
Old Feb 15, 2005 | 03:05 PM
  #26
lohatch's Avatar
Default Re: Engine troubles... (Tad)
it will jump up like that, but it will drop consistently every time you redo the compression test.
Old Feb 15, 2005 | 07:20 PM
  #27
SOHC_MShue's Avatar
Default Re: Engine troubles... (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">and just like on honda-tech too.
**** I am blind
Old Feb 16, 2005 | 02:19 PM
  #28
Tad's Avatar
Tad
Default Re: Engine troubles... (SOHC_MShue)
OK I got the head off..
here are the pics.
a few questions.
do you think that cylinder wall could be fixed just by honing it ?
or would a re-bore be absolutely neccessary?
Does the head look ok? Its got some pockmarks from detonation,
but no melting or scoring like the block..
In this pic(below), you see that other cylinder in the background, does that look like damage to its cylinder wall to you??
Heres the head, close up of the #3 chamber, hows that look to u guys?
Old Feb 16, 2005 | 02:40 PM
  #29
dustin's Avatar
I don't think you are going to be able to hone that out. I'd just get a new shortblock. SOHC should be cheap, no?
Old Feb 16, 2005 | 08:45 PM
  #30
Tad's Avatar
Tad
gotcha,
anyone else?
Old Feb 16, 2005 | 09:32 PM
  #31
fishnfst's Avatar
Not worth rebuilding get a new longblock then you don't have to worry about the block and head... I bet if you pull the pistons the ringlands probably sheared off.
Old Feb 16, 2005 | 09:36 PM
  #32
SOHC_MShue's Avatar
ouch
Old Feb 16, 2005 | 10:23 PM
  #33
Tad's Avatar
Tad
Default Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">Not worth rebuilding get a new longblock then you don't have to worry about the block and head... I bet if you pull the pistons the ringlands probably sheared off. </TD></TR></TABLE>
no i know, thats what i'm doing.
but i'm going to want to try and sell the head for sure,
and if I feel like building the block for higher power/boost later on I might like to do that.
Old Feb 16, 2005 | 10:50 PM
  #34
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">ouch </TD></TR></TABLE>
Old Feb 17, 2005 | 12:47 AM
  #35
Calvinator's Avatar
Default Re: Engine troubles... (PrettyLude)
go visit attarco in san jose..thats where I got my d15b longblock for 200$ out the door. good luck.
Old Feb 17, 2005 | 01:25 AM
  #36
Tad's Avatar
Tad
Default Re: Engine troubles... (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">go visit attarco in san jose..thats where I got my d15b longblock for 200$ out the door. good luck. </TD></TR></TABLE>
thanks man.
I looked up their site,
price is untouchable, I had another guy I was going thru but I might
just have to flake on him.
Old Feb 17, 2005 | 06:33 AM
  #37
Flr Power's Avatar
Try getting real engine management for next time. It will save you troubles like that. Only 6 psi and it blew...
Old Feb 17, 2005 | 11:17 AM
  #38
jdmsiR20's Avatar
Default Re: Engine troubles... (coocoo32)
hey it looks like that deal from matt and japan parts isn't going to go through...
i wouldn't either seeing that attarco can beat it like crazy. i thought attarco was in berkeley though? near the campus-ish...
anyway, yeah i wouldn't deal with trying to fix that block, its just way more economical to buy another one. besides, try finding the correct pistons for it, there's mis-information everywhere about our d15b's...
what management do you intend to run this time around? uber?
Old Feb 17, 2005 | 11:19 AM
  #39
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coocoo32 &raquo;</TD></TR><TR><TD CLASS="quote">Try getting real engine management for next time. It will save you troubles like that. Only 6 psi and it blew...</TD></TR></TABLE>
it wasn't the mangment that blew it...it was the lack of managment after the wire became disconnected.
You should still try to go with something like uberdata though
Modified by SOHC_MShue at 2:32 AM 2/18/2005
Old Feb 17, 2005 | 04:29 PM
  #40
Tad's Avatar
Tad
Argh, Had a long hard day pulling my old motor today,
my back aches
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">it wasn't the mangment that blew it...it was the lack of managment after the wire cam disconnected.
You should still try to go with something like uberdata though </TD></TR></TABLE>
Exactly,
At 6psi(well mine bounces from 6-7 depending on the atmosphere)
the stock JR fueling works just fine.
And mine is actually upped a bit, with the JR map controller.
but with that wire loose, basically the ecu wasn't reading IAT's at ALL..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">hey it looks like that deal from matt and japan parts isn't going to go through...
what management do you intend to run this time around? uber? </TD></TR></TABLE>
Yeah, I called atarco, their d15b is 250, i'm guessing they're going to tax it,
so that makes it 270(even tho their site lists at 225 ) they have a location in San Jose. I might end up just going with matt though, cuz he'll shop for a nice clean one for me, and deliver it to my house, for 320.
plus he's a good guy
As for fuel management,
once I get the money, i'm going to run bigger injectors(most likely stealthmode 450cc's), and have it dynotuned by redzone performance. I already have a chipped/socketed ecu by them.
They happen to prefer Crome over Uberdata, so thats what i'll have.
I wouldnt mind tuning with uberdata with myself, but honestly, I really just don't
have the time/energy to deal with that.
And as for the right now, I'm going to run the JR management,
I think i'll steer clear of the high speed runs though..
thanks 4 all the feedback everyone.
Old Feb 17, 2005 | 10:33 PM
  #41
SOHC_MShue's Avatar
crome is a good option as well
Old Feb 18, 2005 | 05:24 AM
  #42
JDMCRX's Avatar
Man did u lean out and detonate? Looks like ur pistons expanded but its werid side to side or u got alot of crank walk.and its applying pressure from side to side.
Old Feb 18, 2005 | 05:39 AM
  #43
f22b2tdave's Avatar
Default Re: Engine troubles... (JDMCRX)
from that first pic of the longblock you can see where the ringland seems "mising." wouldn't that cause the side to side because of poor piston to wall clearance?
Old Feb 18, 2005 | 07:52 AM
  #44
Flr Power's Avatar
The biggest problem with "jr fmu and map controller" is that it does not pull timing under boost leaving you no room for detonation if you ever go slightly lean.
Old Feb 18, 2005 | 02:05 PM
  #45
Tad's Avatar
Tad
if anyone wants to buy this block ima sell it local for 50buxorz
Old Feb 21, 2005 | 04:14 PM
  #46
Tad's Avatar
Tad
I just got back from attarco,
they are pretty nice and helpful I have to say,
they have 5 d15b's and let me check em out and pick one out before buying. I looked under the valve cover of like 3 and they were all SO clean! way cleaner than my last d15b.
We'll see what the comp/leakdown results are like.
My last engine was amazing in that aspect.
Btw i'm selling the d15b head and block separately,
also have a complete cx motor,
ac/ps stuff, and a stock cluch fs now
http://www.craigslist.org/pen/car/60737155.html
ZcSiR_junkie
Aug 3, 2014 01:07 AM
MrMug3n
Honda Civic (2001 - 2005)
24
Aug 26, 2013 06:30 PM
Sohc Driver
Sep 21, 2003 12:50 PM
Sohc Driver
Sep 21, 2003 11:06 AM
Sohc Driver
