engine misfires under boost.
Old Mar 10, 2010 | 07:44 PM
  #26
95skunkedgsr's Avatar
Default Re: engine misfires under boost.
if you have a advanced auto or auto zone in the area they will test that for free
Old Mar 11, 2010 | 06:33 PM
  #27
lsneo's Avatar
checked the wiring on the MAP and the wires are connected right. Next i will switch back to stock map and see if that helps any. This problem happens at any level of boost.
Old Mar 16, 2010 | 05:32 PM
  #28
Tulo's Avatar
Icon3 Re: engine misfires under boost.
Don't plug in your stock map sensor if it's set up for an aftermarket one! I've been advised that doing so can seriously fv(k some $h!+ up.
If you know someone with the same map sensor as you, just ask if you can swap real quick. It'll either fix your problem or it won't, but at least you'll know.
Old Mar 17, 2010 | 06:52 PM
  #29
lsneo's Avatar
i'm going to buy another map, i don't know anyone with one so i'm stuck buying it.
Old Mar 23, 2010 | 03:33 PM
  #30
lsneo's Avatar
well i noticed that my spark plug wires were arching if i pulled a wire while the car was running. They were ngk so i changed them to stock honda wires and they still arch but not as much. Could this be the cause of the car running like this? They are arching from the boots, not just the bottom of the boot but all from the sleeve.
Old Mar 27, 2010 | 11:28 AM
  #31
TEAM ASSASSIN SI's Avatar
sounds like wires are shot are you running a msd setup
Old Mar 31, 2010 | 03:17 PM
  #32
lsneo's Avatar
no, its a stock set up.
Old Apr 28, 2010 | 08:07 PM
  #33
DUDMD's Avatar
So did you have the problem figured out?
My car is doing the same thing, injectors almost run out and it starts to break up in boost bad. I did manage to lose the break up with a good known dizzy from a friend, though. I think the overlap of the all motor cams is part of the problem. I got the crane stage 2 all motor cams.
LMK if you got it fixed, just want to know what caused it.
Old Apr 29, 2010 | 03:55 AM
  #34
boostfever's Avatar
i would also like to know if you have the problem figured out yet.
my car only made 122hp cause of some interference with the motor but changed everything that my tuner told me to. still acting up so let me know cause would like to get my car up and running before i deploy.
Old Apr 29, 2010 | 01:16 PM
  #35
lsneo's Avatar
no the car has been parked in my garage i have not had time to deal with it. Its funny because i saw both of your threads and was hoping that someone would figure something out.
Old Apr 29, 2010 | 01:36 PM
  #36
slowboy90's Avatar
check your alternator you said the lights are dim. with not enough voltage it wont run right either.
Old Apr 30, 2010 | 04:30 AM
  #37
blazed973's Avatar
check a/f and timing
Old Apr 30, 2010 | 04:31 AM
  #38
blazed973's Avatar
check fuel pressure to
Old Aug 23, 2011 | 07:17 AM
  #39
jdecks23's Avatar
What was the result. Having similar issues....
tommikaira
Dec 3, 2008 09:49 AM
flangemastermike
Nov 15, 2008 08:00 PM
green eyed bandit
Mar 24, 2008 06:27 PM
2coupes
Feb 5, 2008 05:36 PM
dmecarboy
Mar 25, 2003 10:37 PM
