Engine comp question
Old Mar 26, 2009 | 04:01 PM
scspeed's Avatar
Default Engine comp question
I have a built gsr block, JE pistons, eagle rods etc. I was told the motor has 9:1 comp ratio..
If i were to do a compression test...where should my compression be across all four cylinders??
I was thinking around 165 across the board?? LMK Thanks!
Old Mar 26, 2009 | 04:19 PM
civic-r11's Avatar
Default Re: Engine comp question
these varies with every motor..
Old Mar 26, 2009 | 04:28 PM
scspeed's Avatar
ok well what would a round about be? anywhere from 155-175?
Old Mar 26, 2009 | 04:42 PM
E85B18's Avatar
Your head gasket makes it vary. What are you running?
Old Mar 26, 2009 | 06:36 PM
scspeed's Avatar
tripple layer gasket
ben h
15
Apr 24, 2012 01:08 PM
2kflamedlude
Apr 25, 2004 06:01 AM
Silverhatch
Apr 8, 2004 05:36 PM
spaceman
Mar 30, 2004 09:36 PM
BlackGSR
Mar 12, 2002 11:11 PM
