Engine builders please help. Dart block problem
Old Mar 30, 2003 | 05:09 PM
turboex's Avatar
Default Engine builders please help. Dart block problem
Ok we have a dart block with an 84.5mm bore and a gsr head that was fixed to run on an older b20 block, (ls/vtec style so the oil port in the head has been sealed). Ok we used a B20 headgasket on the block and come to find out the dart block is based of a GSR block so the oil feed for the head was in the block but the LS gasket did not cover it. So is a GSR gasket going to work? Is the the same bord as the b20? We thought about drilling out the plug thats in the GSR head. Any recomendations? thanks
Old Mar 30, 2003 | 06:21 PM
hybrid901's Avatar
Default Re: Engine builders please help. Dart block problem (turboex)
I would use a gsr gasket and untap the head. No sense in having a external oil line unless you have to.
Old Mar 30, 2003 | 06:25 PM
turboex's Avatar
Default Re: Engine builders please help. Dart block problem (hybrid901)
So a stock GSR headgasket is over 84.5mm? True with the hole, its just that the hole has a brass pin in there. Ill have the machine shop take it out
Old Mar 30, 2003 | 06:29 PM
hybrid901's Avatar
I hope you know a gsr head gasket is 81mm if you are building this block. You can either get a cometic gasket or a stock one bored out from GEM. I have a 84.5mm stock vtec gasket from GEM in stock if you need one.
Old Mar 30, 2003 | 06:33 PM
turboex's Avatar
Holla your the man, shoot me your adress and shop info to damianhindley@min.midco.net and what kind of payment i can do. cash, visa, what ever. thanks man oh and the price, thanks again
Old Apr 3, 2003 | 09:46 AM
hybrid901's Avatar
TurboEX please call me at work. The credit card # you gave me didn't work. I already send out the headgasket to you. You should receive it today. Please call me 901-377-0027.
Josh
Old Apr 3, 2003 | 12:12 PM
turboex's Avatar
no problem he will be calling you today
CW-ITR
10
Oct 5, 2007 11:43 AM
Topdawgg
Apr 9, 2007 09:29 AM
Prelude91siT
Mar 24, 2005 07:41 PM
turboex
Nov 20, 2002 04:40 PM
masterk0ns
Jul 27, 2002 07:23 PM
