endyn piston ring gap
Old Apr 14, 2003 | 05:02 PM
bretx0r's Avatar
Default endyn piston ring gap
I got my rings gapped and the guy who gapped them said that when he put them in the bore WITHOUT FILING them it was 0.015 which is out of endyn's specs for 81mm bore... what should i do?
Old Apr 14, 2003 | 05:18 PM
Boostfed's Avatar
New User
Default Re: endyn piston ring gap (bretx0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bretx0r &raquo;</TD></TR><TR><TD CLASS="quote">I got my rings gapped and the guy who gapped them said that when he put them in the bore WITHOUT FILING them it was 0.015 which is out of endyn's specs for 81mm bore... what should i do?
This is what my end gaps were also when I got my block bored and honed from GE, my local machine shop said it was a little looser than he likes or Endyn recommends but still useable. Don't file anymore from the rings now then, run it alittle loose is all you can do. Good luck.
Old Apr 14, 2003 | 05:33 PM
bretx0r's Avatar
Default Re: endyn piston ring gap (Boostfed)
hmm... anyone else experience this?
Old Apr 14, 2003 | 05:38 PM
Sonny's Avatar
Your machine shop must've taken a lot of material out of the bore. What is the piston-to-wall clearance? Mine was .0029 and my rings had almost no gap at all. (75.5mm bore Endyn pistons)
You'll be fine with that ring gap though. That's a little loose, but I doubt it will cause any problems. That's definitely better than having them too tight.
Sonny
Old Apr 14, 2003 | 06:05 PM
bretx0r's Avatar
Default Re: endyn piston ring gap (Sonny)
they must have...
my pistons are 81mm bore...
i was thinking about measuring the bore iwth a micrometer to see just how much he took off
Old Apr 14, 2003 | 07:37 PM
bretx0r's Avatar
ttt
Old Apr 14, 2003 | 09:07 PM
boostaholic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">That's a little loose, but I doubt it will cause any problems. That's definitely better than having them too tight.
Sonny</TD></TR></TABLE>
Definitely better than having them too tight. Too tight and when they really heat up the rings can bind and give you alot more problems.
Old Apr 15, 2003 | 11:26 PM
bretx0r's Avatar
ttt
Old May 8, 2003 | 03:55 AM
Turbo92Si's Avatar
Got my block back a few days ago from Golden Eagle(84mm bore). Also got new Endyne pistons. I started checking my rings gaps and i was getting .017. Is this ok cause Endyne says they should be around .012-.013? How much will they swell when the block is at normal operating temp?
Old May 8, 2003 | 04:28 AM
sgT's Avatar
sgT
Default Re: endyn piston ring gap (Turbo92Si)
i usually run .014" on 84-85mm and I have to file to get that.
Mypiston to wall clearance is also like .035
Old May 9, 2003 | 04:00 AM
Turbo92Si's Avatar
Default Re: endyn piston ring gap (sgT)
_______
Isn't that to much? Endyne calls for .0028-.0029 for a 84.5mm bore for Turbo app. I think u meant to say maybe .0035. But they say .0031-.0032 is for a 87mm.
http://Hybridynamics.com
Old May 11, 2003 | 06:14 AM
Turbo92Si's Avatar
bump for some more answers
nychonda
Apr 12, 2011 05:59 PM
Muckman
Feb 23, 2007 11:04 PM
FIGARILA
Jan 12, 2007 12:03 PM
Modern91Hatch
Jul 13, 2006 02:57 PM
turbodohcsi
Jan 1, 2005 10:22 AM
