ENDYN Oil Pump Mods
Old Mar 7, 2006 | 05:56 PM
BLKTeg94's Avatar
Default ENDYN Oil Pump Mods
Just curious on if anyone is running an oil pump modded by ENDYN and if they've liked em. I'm kind of debating on having them do mine or just going with the stock OEM. Let me know what you guys think? It's $135 for the mods.
Here's the Link:
http://www.theoldone.com/compo...s.htm
Old Mar 7, 2006 | 06:33 PM
tepid1's Avatar
Default Re: ENDYN Oil Pump Mods (BLKTeg94)
Bump for you .... I would like to know too
Old Mar 7, 2006 | 06:58 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ENDYN Oil Pump Mods (tepid1)
I have one and loved it. I am getting another one for my new build.
art
Old Mar 7, 2006 | 07:00 PM
Adi Radoncic's Avatar
On Fire!
Default Re: ENDYN Oil Pump Mods (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I have one and loved it. I am getting another one for my new build.
art</TD></TR></TABLE>
Wtf is done to it, lover?
Old Mar 7, 2006 | 07:06 PM
BLKTeg94's Avatar
Our oil pump modifications reduce pump cavitation at extreme engine speeds and increase output by reducing losses, netting more power at the crank. Each pump is machined to achieve minimum rotor to case clearances, by-pass valves are clearanced to prevent binding, inlet and outlet passages are bored to larger diameters, tapered, radiused, and back-filled. *quoted from ENDYN website*
Old Mar 7, 2006 | 07:07 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: ENDYN Oil Pump Mods (Adi Radoncic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adi Radoncic &raquo;</TD></TR><TR><TD CLASS="quote">
Wtf is done to it, lover? </TD></TR></TABLE>
watch out there buddy, you've been watching too much broke back mountain.
Old Mar 7, 2006 | 08:03 PM
BLKTeg94's Avatar
bump to see if anyone is running these?
Old Mar 7, 2006 | 08:10 PM
USDM 4G VTEC's Avatar
i have done the same modifications myself
and even an aditional one at the output from the rotor to the outter passage, and it works great on oil flow
Old Mar 7, 2006 | 09:16 PM
Suprdave's Avatar
I've used one...it worked. That being said, and Oil pump is one of those things that either works or it doesn't...so whose to say if the modifications do anything.
Old Mar 8, 2006 | 05:05 AM
.nate's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have done the same modifications myself
and even an aditional one at the output from the rotor to the outter passage, and it works great on oil flow</TD></TR></TABLE>
Can you elaborate?
Old Mar 8, 2006 | 05:33 AM
dc2turbo's Avatar
Default Re: (.nate)
Will it change the oil pressure any?
Old Mar 8, 2006 | 04:42 PM
allen7-civic's Avatar
bump again for more info
Old Mar 8, 2006 | 04:46 PM
nfn15037's Avatar
Default Re: (allen7-civic)
I backfilled, ported and radiused the pump outlet on several customer and personal oil pumps. Simple fluid dynamics says that it should flow better( far less turbulence in the oil flow). It is easy to do and relatively inexpensive to have someone else do it, so might as well in those high end builds. I like a good supply of high pressure oil, but not as much as my engine does
Mr. Future
Nov 22, 2015 07:46 PM
Circuit Star-29
May 5, 2006 09:40 PM
Serdar
Oct 12, 2005 12:10 AM
StolenTeg
Oct 3, 2004 06:50 PM
Machine1
Feb 8, 2004 07:40 PM
