Emanage question?
Old Jun 2, 2005 | 08:09 PM
lpfreak13's Avatar
Default Emanage question?
I was wondering if it is necessary for me to buy the pressure sensor and the pressure sensor harness in order to run boost.
Old Jun 3, 2005 | 07:41 AM
lpfreak13's Avatar
Default Re: Emanage question? (lpfreak13)
bump???
Old Jun 3, 2005 | 09:56 AM
CASH's Avatar
It is recommended but not a must. U can also run the stock map sensor and when tuning set the map sensor voltage constant across the rpm. i was getting a check light before and after tuning and setting this there was no more problem...
Old Jun 6, 2005 | 05:03 AM
lpfreak13's Avatar
Default Re: Emanage question? (CASH)
all right thanks for the information.
Old Jun 10, 2005 | 08:42 PM
H22A EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASH &raquo;</TD></TR><TR><TD CLASS="quote">It is recommended but not a must. U can also run the stock map sensor and when tuning set the map sensor voltage constant across the rpm. i was getting a check light before and after tuning and setting this there was no more problem...</TD></TR></TABLE>
what did you tune i and having probs with mine similar to yours sorry for the therd jack
Jthw
Engine Management and Tuning
Oct 30, 2016 12:07 PM
weziebme
Mar 2, 2008 02:22 PM
T9U4ReBgO
Feb 20, 2008 05:55 PM
Dr Pooface
Nov 19, 2005 12:37 PM
agratise
Feb 24, 2005 05:48 AM
