EM1 Motor mount question..
Who is Mr Robot?
i have a 99 em1. im using the innovative mount kit (upper solid mount, tranny side solid mount and rear solid mount)
my question is this... the mounts are 60A urethane... pretty stiff stuff. can i get away with not using the lower tranny mount in the front and the bracket for where the ac compressor used to mount?
Who is Mr Robot?
because A) the two lower mounts are ugly.. showcar
B) solid urethane in 3 places plus a torque dampener should be more than enough to keep the motor from moving.
http://cgi.ebay.com/ebaymotors...wItem
thats the mount kit im using.... i dont see why they are needed anymore... solid mount in the middle of the motor in the rear keeps it from flexing.. the urethane should be able to stop it from moving without the torque mounts.... but like i said im open to opinions
Who is Mr Robot?
but do you have stock motor mounts all the way around? i dont... mine arent stock... completely solid 60a urethane filled afermarket upper drivers side mount, upper tranny mount and rear mount
no, you wont be ok..........
you want to put the mounts on. you have 2 mounts that are inline with the crank. you want to use the 2 lowers because it will distribut the power into the chassis/suspension instead of rotating the engine on the center axis... like an engine plate in a sence.
yea, im bad at explaining ****
Who is Mr Robot?
about a year ago... dont forget i have your money in my possession... play nice
so i guess i need the lower mounts. ill probably use the oem tranny side mount and have it powdercoated.... im thinking about fabbing the ac mount myself
.so i guess i need the lower mounts. ill probably use the oem tranny side mount and have it powdercoated.... im thinking about fabbing the ac mount myself
obuhmyuh
26
Nov 5, 2008 02:30 PM
Razr2
18
Mar 15, 2008 08:59 PM
onyx00
Sep 24, 2004 01:00 PM
