EK Turbo ????
Old Mar 12, 2013 | 11:00 PM
rex89sir2's Avatar
Default EK Turbo ????
OK i know that theres write up everywhere but not answering my specific question/s.
97 ek coupe d16y8 completely stock other then exhaust
im wanting to know the best turbo to get? only going to be running 8-9lbs at the absolute most only looking for 175-200 hp. motor is strong great compresion across the board. I dont want an ebay turbo from what ive heard
t-25 is alot of peoples choice and some like the 14b but say its to small if i was looking at a t3 50 trim maybe .48ar? also is it a must to do the fuel pump with a walbro 255 and since im not looking for crasy number?? thanks alot and sorry if this has been asked over and over again just looking for a solid answer
Tim
and also i want to keep my ac so what kind of manifolds should i be looking at? and i have my resistor box off my 90hf will this work with the 440 DSM
Old Mar 12, 2013 | 11:03 PM
rex89sir2's Avatar
Default Re: EK Turbo ????
and what about something like this?? and if its needs to be rebuilt is it worth it?
http://orlando.craigslist.org/pts/3658718627.html
Old Mar 13, 2013 | 12:07 AM
yungkhmer's Avatar
175-200hp?! ... dude. just stay all motor. that link u posted, its junk.
Old Mar 13, 2013 | 03:06 AM
grumblemarc's Avatar
The Grumpiest
BUDGET?
Can't have champagne taste if your pockets got Kool-aid money.
Old Mar 13, 2013 | 03:29 AM
Balor_Gr's Avatar
http://www.spoolinperformance.com/ga...a5c3f3ea83d169
Garrett t3 super 60 .48 a/r 565$
Old Mar 14, 2013 | 07:02 AM
Schister66's Avatar
Man U FTW
There's no chance in hell he can make that power NA...great advice I agree the parts in the link are not worth buying.
If you're going to boost your car reliably, you need to research and understand what you're doing. The FAQ may not exactly answer your questions, but will guide you to setups with similar goals to yours. Forget the PSI goal for now and focus on a power goal...keep it less than 220-240whp. For those goals, find a T3 Super60 .63ar or T3/To4B 50 trim .63 ar and be on your way. There are cheaper OEM turbos that may work, but the effort involved to make them work, isn't worth your time. Go with a new or gently used Garrett, like the ones listed above.
Old Mar 14, 2013 | 02:24 PM
rex89sir2's Avatar
I'm glad someone said said it cause 175-200whp on a y8 would cost me more then the cars worth lol but thank you for the advice. I think I'm going to go with the 50 trim seeing is how u can't buy a manifold for the t25
Slider617
Aug 1, 2013 08:37 PM
HamiltonRex
Jan 14, 2008 11:41 AM
smooth95
May 23, 2005 09:45 AM
