EGT's Explained! Your answers are HERE
Old Mar 27, 2008 | 11:09 AM
  #51
anton_'s Avatar
Default Re: EGT's Explained! Your answers are HERE (steven_highet)
i checked the temp on each runners on the manifold with a ir-temp.
cylinder 3 was about 30-50C hotter on the third cylinder,
in neptune there is a fuel cylinder trim, should you give that cyl some more fuel som it wont go hotter than the others?
Old Mar 27, 2008 | 11:50 AM
  #52
RACEPAK's Avatar
old scool
Old Mar 27, 2008 | 04:03 PM
  #53
matt k's Avatar
you need some sort of egt amp for it to work<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven_highet &raquo;</TD></TR><TR><TD CLASS="quote">You can just buy a sensor and use S300 to datalog your EGT's and see what you EGT's are doing in reference to A/F, Timing, Load and so on. Makes it alot easier to see it graphed out than to watch it while driving.</TD></TR></TABLE>
Old Mar 27, 2008 | 05:01 PM
  #54
dai-18t's Avatar
I am setting up individual cylinder egts on my motec and the only reason for it is for individual cylinder trim while thecar is being tuned.
For that i see egt as being helpfull.
Old Mar 27, 2008 | 05:14 PM
  #55
90civichbsi's Avatar
Default Re: (dai-18t)
ok i have a question regarding overall engine temp and tune. before my car was stolen I had a stock b16 on 7.5 lbs and hondata s200. fluidyne radiator flexalite fan.
during the summer over 90 degrees my car would always try to overheat, especially on the highway. the only way i could regulate temps was by regulating egts. I would get up to speed (watching the EGT's climb) then let it coast till the EGT's dropped a fair amount. as soon as i engaged the throttle again the water temp would drop about 10 degrees..
i would just have to repeat this over and over on longer drives. Do you think this is due to the tune or what?
Old Mar 28, 2008 | 09:13 AM
  #56
Devine's Avatar
Default Re: (90civichbsi)
Wow back from the dead, i knew something was up when i saw the OP was vaportrail.
Old Dec 19, 2017 | 08:38 AM
  #57
all<dc5's Avatar
Originally Posted by VaporTrail
Peak EGT generally occurs at an AFR of around 14.7- 15.0 to 1 on gasoline.
Sure about this? In my ICE classes I learned peak EGTs generally occur at about 10% richer than stoich.
Old Dec 19, 2017 | 09:38 AM
  #58
TheShodan's Avatar
Moderator
We appreciate the comment, but this was 9 years ago. This person hasn't posted in years. EGTs aren't measured in the same way as AFR in terms of "rich" or "lean" by percentage. The temperature only points to what is going on with the condition of the engine by way of the spark plugs. In rotary engines that ratio changes due to the characteristics of the rotary engine itself. So, don't look at your % example as a complete rule.
Few people even run EGT gauges now. They simply pull the plug every time the car makes a complete run on the dynamometer.
4drEF
Aug 24, 2012 06:07 AM
teri_vti
Apr 14, 2005 05:54 PM
azn98R
Feb 24, 2003 05:08 PM
gigantor
Aug 28, 2002 03:37 AM
bQQsted hybrid
Aug 4, 2002 08:09 PM
