egt sensor resistance?
Old Jan 1, 2006 | 02:25 PM
RACEPAK's Avatar
Default egt sensor resistance?
hello everybody.
anyone know the approximet resistance of a egt k-serise prob?
thnks
Old Jan 1, 2006 | 02:53 PM
mrx's Avatar
mrx
Default Re: egt sensor resistance? (RACEPAK)
a egt probe has no resistance, its some kind of voltage source which generates a very small amount of voltage (mV) ... if you want to read such a sensor you need a amplifier with a very high input resistance...
maybe you can explain what you want to do.
hope that helps.
Best regards
Malte.
Old Jan 1, 2006 | 02:59 PM
The Weather Man's Avatar
Well technically it reads resistance....thus the name a thermistor; however, I wouldn't know how to read it.
More resistance, less voltage, different reading
less resistance, more voltage, different reading
no resistance, source voltage, different reading
So, it has everything to do with resistance. It doesn't "generate" voltage at al.
Old Jan 1, 2006 | 03:10 PM
RACEPAK's Avatar
Default Re: (TheKINGPin)
well... i'm arguing with a few guys on our local form about how to install a etg.
i tryed to help this guy and i said that he need to solder the wire to the gauge, and thay said that that the led will be a kind of a resistor...
thay said that twisting the wires togther will be better.
Old Jan 1, 2006 | 03:22 PM
Importordomestic's Avatar
Datat sheet for Bosch TCP-K series probe, not sure if that is what you mean
http://www.bosch-motorsport.de...K.pdf
SWAT
Engine Management and Tuning
Jan 11, 2011 03:26 PM
Supa Troopa
Mar 23, 2010 07:35 PM
trooper0641
Jun 13, 2005 04:34 AM
mntuner2
Aug 4, 2003 12:07 PM
Black R
Jun 25, 2003 11:44 PM
