egt probe question.............................
Old Jul 23, 2003 | 07:49 AM
gtconcepts's Avatar
Default egt probe question.............................
im installing a egt but im not sure in witch piston the probe goes , is it piston #1 or piston #4 ..
thanks guys ....
Old Jul 23, 2003 | 08:38 AM
FULLTHROTTLE's Avatar
Default Re: egt probe question............................. (jerseykid609)
what about in the collector? No good? Probably too far away to tune timing correctly eh?
Old Jul 23, 2003 | 08:54 AM
platinum00's Avatar
Default Re: egt probe question............................. (FULLTHROTTLE)
im wondering the same thing
i really dont want to tap my manifold. can i put it in the top of the downpipe.
what are the drawbacks of not taping #3 in the right spot..
platinum.
Old Jul 23, 2003 | 09:01 AM
coos's Avatar
Default Re: egt probe question............................. (platinum00)
tap the manifold!!!!!!!!!! and yes put it on the third runner.......
Old Jul 23, 2003 | 09:31 AM
grndcont's Avatar
it needs to be placed from the head 1.5 times the diamiter of the exaust port. (i.e. very f'in close) the # 3 and #2 would be ideal, however #1 or 4 would work ok too.
Old Jul 23, 2003 | 09:56 AM
integra-modder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">im wondering the same thing
platinum.</TD></TR></TABLE>
Picture this: You have a burning candle and you want to find out the temperture at which its burning. To get an accurate measurement, would you hold your measuring device at the tip of the candle, a few inches above the flame, or around the blue part of the flame...
the point is, you want to get as close to the souce of the flame which is right after the exhuast gasses leave the cylinder. On Honda's cylinder 3 appears to be the hottest, so use that as your measuring source...
Old Jul 23, 2003 | 10:09 AM
NuclearB18B's Avatar
Default Re: egt probe question............................. (integra-modder)
i know this is a really dumb question...but which one is the #3 runner?
Old Jul 23, 2003 | 10:56 AM
symba's Avatar
Default Re: egt probe question............................. (ha illuminato un)
If you are standing in front of your car and looking down into the engine, then the far left (passenger side) is 4 and so on 3, 2, 1. 1 being on the far right (driver's side)
Old Jul 23, 2003 | 11:29 AM
FuzzyGreen's Avatar
Does anyone have a picture of an autometer EGT probe welded in to a manifold? I need to make sure the part I have for the bung is the correct part. Thanks!
Ash J. Williams
Apr 2, 2013 07:37 AM
RNPoo7
May 29, 2004 08:49 AM
FredoSP
Feb 9, 2004 07:28 AM
01ITR#700
Jul 2, 2003 03:41 PM
FBP Si 2000
Mar 23, 2002 07:12 PM
